Using Photovoltaic Panel to Positively Charge Bidum Surface for Mussel Spat Attachment
267 10
Can I use a small photovoltaic panel to create a positive electrical charge across a mussel spat collector surface so that spat are more likely to attach?
Yes, you can power electrodes from a solar panel, but in seawater you will really be creating a current/voltage between contacts rather than a simple “positive charge” across the whole surface [#21667090] Use the panel to charge a battery in daylight, then feed the battery through a resistor to the external contacts; a diode prevents the battery from discharging back through the solar cell at night [#21667091][#21667099] Try different polarities and spacing between the contacts, and experiment with resistor values from about 1 kΩ to 50 kΩ to see whether spat prefer the positive side or avoid the current path [#21667090][#21667091] Because seawater is highly conductive, a stronger field over a larger area may require a large conductive mesh or other corrosion-resistant electrode material [#21667092] The solar cell and wiring will need very good waterproofing and mechanical protection in the surf [#21667090][#21667092]
  • Feasibility of positively charging bidum with a solar panel
    #1 21667089
    Bruce Goodwin
  • Solar panel setup for seawater current testing
    #2 21667090
    Frank Bushnell
  • Solar light battery circuit with current-limiting resistor
    #3 21667091
    Frank Bushnell
  • Silicone II and corrosion-resistant mesh recommended
    #4 21667092
    Steve Lawson
  • Positive field may be a red herring
    #5 21667093
    Steve Lawson
  • High-voltage field suggested for seawater contacts
    #6 21667094
    Frank Bushnell
  • #7 21667095
    Steve Lawson
  • #8 21667096
    Steve Lawson
  • #9 21667097
    Steve Lawson
  • Plans a simple solar-light prototype and field trial
    #10 21667098
    Bruce Goodwin
  • 1N400x diodes and battery-backed solar charging
    #11 21667099
    Frank Bushnell
The discussion addresses the feasibility of using a small photovoltaic (PV) panel to generate a positive electrical charge on a bidum (polypropylene/nylon) surface to enhance mussel spat attachment in marine reseeding projects. It is technically possible to connect a solar panel to electrodes placed on or near the substrate, using seawater's conductivity to create an electric field. Experimentation with electrode polarity, spacing, and current strength is recommended to observe mussel settlement preferences. Incorporating a voltage regulator and a battery charged by the solar panel can maintain a controlled voltage, including nighttime operation. Waterproofing of electrical components is critical, with silicone sealants recommended but with caution to avoid corrosion from acetic acid in some types; ammonia-based silicone (Silicone II) is preferred if fresh. Due to seawater's high conductivity, generating a strong positive field over a large area may require a substantial PV array and corrosion-resistant conductive materials such as carbon pads, stainless steel mesh, or conductive plastics. A simple, low-current setup can be derived from repurposed garden solar LED lights, using diodes (e.g., 1N400x series) to prevent battery discharge and resistors (1 kΩ to 50 kΩ) to limit current. The possibility that mussel spat attraction is influenced by chemical or biological factors rather than purely electrical fields is also noted. A pilot project is planned to test these concepts with community involvement and data collection.
