LM4562 Destroyed on Power Up, Audible Hum from C2 Coupling Capacitor Surge
288 11
How can I prevent a coupling capacitor from sending a turn-on surge into an LM4562 input and destroying the op-amp when B+ is applied?
Use input clamping and current limiting so the turn-on pulse cannot drive the LM4562 input above its rails; the coupling capacitor alone is not enough protection. When B+ is switched on with a fast edge, the capacitor couples that pulse and the input can see excess voltage until it discharges through R6, which is too large to damp the pulse [#21675854][#21675857] Add a series resistor at the op-amp input and clamp the node with ESD diodes to the supply rails or with a pair of fast zeners back-to-back to ground so the op-amp’s internal diodes are not overloaded [#21675857] Another option is to put a resistor or series inductor in series with B+ to form an RC/LC low-pass with C1, possibly increasing C1 if needed [#21675857] A pair of anti-parallel diodes at the IC input to ground was also suggested as a similar fix [#21675859]
  • Power-up surge through C2 may be killing LM4562
    #1 21675853
    Charles Johnson
  • Excess startup voltage likely damaging opamp input
    #2 21675854
    richard gabric
  • #3 21675855
    Charles Johnson
  • #4 21675856
    Kevin Angelo Ma
  • Power-on surge mitigation with series resistor and clamp diodes
    #5 21675857
    Dean Franks
  • #6 21675858
    Charles Johnson
  • #7 21675859
    Charles Johnson
  • #8 21675860
    Sambath Kumar
  • #9 21675861
    Charles Johnson
  • #10 21675862
    Sambath Kumar
  • #11 21675863
    Sambath Kumar
  • #12 21675864
    Charles Johnson
The discussion addresses a circuit issue where applying B+ voltage to the plate causes an initial audible hum, indicating a surge through the coupling capacitor C2, and sometimes results in destruction of the LM4562 op amp. The hum may disappear during normal operation, but the op amp can be damaged due to excessive voltage at the non-inverting input during power-up before discharge through resistor R6. Suggested solutions include adding diodes to clamp input voltage spikes, placing a resistor or series inductor in series with the power supply to create an RC or LC low-pass filter with the input capacitor, and increasing the input capacitor value. Additional recommendations involve using ESD protection diodes between the coupling capacitor output and the op amp supply rails, and adding a series resistor at the op amp input to limit current through internal ESD diodes. Anti-parallel diode pairs and fast zener diodes were also proposed to protect the op amp from voltage surges. The importance of proper power switching and input protection to prevent damage to the LM4562 was emphasized.
TL;DR: Startup damage and hum come from a surge through the coupling cap; the thread reports “one of two things take place” and 2 outcomes total. Add input clamps and slow the B+ edge. [Elektroda, Charles Johnson, post #21675853]
Why it matters: This FAQ shows how to stop LM4562 inputs from seeing destructive startup transients in cap‑coupled tube/solid‑state hybrids.
What causes the LM4562 to blow on power‑up here?
A fast B+ turn‑on edge couples through C2 into the non‑inverting input. With R6 large, the pulse is not damped, so the input sees an overvoltage and the op‑amp can fail. Adding a clamp and limiting the pulse current fixes this. [Elektroda, Dean Franks, post #21675857]
Why do I hear an audible hum from C2 at startup?
The hum flags a surge current through the coupling capacitor during B+ application. That transient current injects a pulse into the op‑amp input until the node discharges through R6. Once it settles, the hum disappears. [Elektroda, Charles Johnson, post #21675853]
How do I protect the op‑amp input from the surge?
Clamp the cap’s output node with a pair of ESD diodes to the V+/V− rails and add a small series resistor before the op‑amp input. This limits current and keeps the input within safe limits during the pulse. [Elektroda, Dean Franks, post #21675857]
Where exactly should I place the ESD or clamp diodes?
Connect the ESD diodes from the node after C2 to V+ and to V−. Keep leads short. This shunts the pulse energy away from the input. A quoted tip: “A pair of ESD diodes… would be a good addition.” [Elektroda, Dean Franks, post #21675857]
Do I need a series resistor on the op‑amp input, and will it change gain?
Yes, add a series resistor between C2 and the op‑amp input to limit surge current. It does not change the closed‑loop gain when placed before the non‑inverting input. It just protects during transients. [Elektroda, Dean Franks, post #21675857]
Should I add resistance or inductance in the B+ line to slow the edge?
Yes. Put a resistor or small inductor in series with B+ so C1 forms an RC/LC low‑pass. You can also increase C1. Slowing the edge reduces how much of it C2 couples forward. [Elektroda, Dean Franks, post #21675857]
Is R7 actually doing anything useful in this schematic?
No. As drawn, R7 does not contribute to a valid op‑amp configuration and should be removed or repurposed. Recheck the gain network and biasing. [Elektroda, richard gabric, post #21675854]
What does “B+” mean in this context?
B+ is the high‑voltage supply feeding the tube plate. Switching B+ on creates a fast edge that can capacitively couple into the op‑amp front end through C2. [Elektroda, Dean Franks, post #21675857]
What is a coupling capacitor, and why can it surge?
A coupling capacitor (C2) passes AC while blocking DC between stages. When B+ steps quickly, the capacitor momentarily passes a large transient until the downstream node discharges via its resistive path. [Elektroda, Charles Johnson, post #21675853]
Quick 3‑step fix to stop startup destruction?
  1. Add a pair of ESD diodes from the C2 output node to V+ and V−.
  2. Insert a small series resistor before the op‑amp input.
  3. Add series R/L in B+ and consider increasing C1 to slow the edge. [Elektroda, Dean Franks, post #21675857]
Can I use back‑to‑back zeners instead of ESD diodes?
Yes. Use a pair of fast zeners head‑to‑head from the C2 output node to ground, plus the series input resistor. This clamps the transient similarly to rail‑clamps. [Elektroda, Dean Franks, post #21675857]
Why did the circuit sometimes work and sometimes kill the LM4562?
The startup pulse amplitude varies with conditions, so outcomes alternate. The thread reported two outcomes: normal operation or failure after the hum. Clamping removes that variability. [Elektroda, Charles Johnson, post #21675853]
Do I need to change C1 or C2 values to help?
Increasing C1 helps form a stronger low‑pass with added series R/L, reducing the edge. Keep C2 as designed for bandwidth, but protect its output with clamps and a series resistor. [Elektroda, Dean Franks, post #21675857]
Is there a simple ground‑referenced clamp option?
Yes. Anti‑parallel small‑signal diodes from the op‑amp + input to ground were suggested. This provides bidirectional clamping at that node. [Elektroda, Charles Johnson, post #21675859]
What edge case should I watch for with slow‑ramp supplies?
If B+ ramps slowly, the transient shrinks, and failures may appear to vanish. However, a later fast restart can still exceed limits. Keep the input clamps. [Elektroda, Dean Franks, post #21675857]
Was forum etiquette addressed in this thread?
Yes. Participants asked to keep discussions constructive, then the original poster apologized and proceeded with technical fixes. Stay focused and share results. [Elektroda, Kevin Angelo Ma, post #21675856]
