How to Calculate Electronics Formulas and Compare to Measured Values in Class?
240 7
  • Request for help comparing calculated and measured values
    #1 21677406
    nabila hussain
  • #2 21677407
    Richard Shadbolt
  • #3 21677408
    nabila hussain
  • Correcting resistor value and current formula for LED circuit
    #4 21677409
    Richard Shadbolt
  • Plans to redo 9 V measurements with a digital voltmeter
    #5 21677410
    nabila hussain
  • Worked example for calculating parallel and series resistor values
    #6 21677411
    Richard Shadbolt
  • #7 21677412
    nabila hussain
  • Resistor tolerance caused mismatched lab results
    #8 21677413
    Conrad Mannering
A teacher covering an electronics unit sought assistance with calculating circuit values and reconciling these with measured results, noting discrepancies. The discussion highlighted issues such as incorrect resistor values in calculations (e.g., a 200Ω resistor mistakenly used instead of 100Ω), the impact of diode internal resistance on voltage and current calculations, and the influence of measurement tools like ammeters and digital voltmeters on accuracy. Step-by-step formulas were provided for calculating equivalent parallel resistance (Rp), total resistance (Rt), current (I), individual branch currents (Ir1, Ir3), and voltage drops across resistors and diodes, emphasizing the importance of accurate voltage measurements at the power supply and diode. Additionally, practical considerations were raised regarding resistor tolerance (5%-10%) causing variations in measured values among students, suggesting the use of matched resistor sets to improve consistency. The discussion also recommended sharing pooled results to analyze statistical distribution of measurements.
