Definition and Determination of Coupling Length in Multiconductor Shielded Cables
285 6
  • #1 21677710
    Emmanuel Kazeera
  • #2 21677711
    Neil Mula
  • Clarifying coupling length for transfer impedance tests
    #3 21677712
    Emmanuel Kazeera
  • Coupling length depends on cable materials and setup
    #4 21677713
    Neil Mula
  • Standards should define coupling length test setup
    #5 21677714
    richard gabric
  • 1 m test length as coupling length estimate
    #6 21677715
    richard gabric
  • #7 21677716
    Emmanuel Kazeera
The discussion clarifies the definition and determination of coupling length in multiconductor shielded cables during transfer impedance testing, specifically using the Triaxial Chamber method. Coupling length refers to the length of the cable sample under test that is subjected to electromagnetic stress and energy transfer between conductors. It is effectively the physical length of the cable segment used in the measurement setup, commonly 1 meter. The coupling length is critical in electromagnetics and transmission line theory, influencing transfer impedance results. Standards such as IEC typically define test parameters including coupling length, which corresponds to the test sample length threaded through the test apparatus. The coupling length depends on cable construction, materials, and test configuration. Network analyzer documentation confirms that the coupling length equals the stressed sample length, validating the 1-meter test length used in practice.
