Sorry in advance if the question is silly for someone. I need to change the output voltage between 3.2-3.6 V to receive the square waves while their resolution could be received with signal generator ( the resolution is too high). However, the SG does not produce enough output voltage so some DC biasing should be added. I use picoscope 5000 as a SG and I am afraid that if I use it in series with power supply it will be burnt. What are the simple and safe ways to add biasing to SG? Thank you in advance.
Ruslan Tazhkenov
Ruslan Tazhkenov
