Isolating Analog Voltage for PIC Microcontroller Using Opto-Isolator: Safe Method?
255 7
  • #1 21676800
    memonasser afeef
  • #2 21676801
    memonasser afeef
  • Optocouplers are poor for linear analog isolation
    #3 21676802
    richard gabric
  • #4 21676803
    memonasser afeef
  • Adjusting resistor values to fit input voltage range
    #5 21676804
    richard gabric
  • #6 21676805
    memonasser afeef
  • Recommend transformer or Hall sensor for high-voltage measurement
    #7 21676806
    richard gabric
  • #8 21676807
    Tim Huan
The discussion addresses the safety and feasibility of measuring analog voltage with a PIC microcontroller using an opto-isolator for isolation. The circuit in question is a difference amplifier with gain, typically involving an LM258 op-amp, and the user is concerned about protecting the microcontroller from high voltage damage. It is noted that a simple opto-isolator does not provide a linear analog output over a wide dynamic range, and specialized high-linearity optocouplers or alternative isolation methods may be required. The importance of proper PCB layout, resistor voltage ratings, and safety considerations is emphasized, especially when measuring high voltages (potentially hundreds of volts). Alternatives such as using transformers for AC voltage stepping down or Hall effect sensors for current measurement are suggested. Additionally, isolated DC-DC power supplies with push-pull circuits can be used to achieve galvanic isolation for different loads. Overall, while the circuit may be safe under normal conditions without hazardous voltages or ground loops, careful design and component selection are critical to ensure microcontroller protection and measurement accuracy.
