SC200 Power Amplifier: Correct Bias Resistor Value, BC556B/BC546B Gain Impact, F2 Fuse
387 6
  • Bias resistor discrepancy and possible BC556B/BC546B stability issue
    #1 21679277
    huddslad huddslad
  • Improperly mounted driver resistor caused amplifier fault
    #2 21679278
    huddslad huddslad
  • Shorted output likely caused fuse and component failure
    #3 21679279
    Richard Shadbolt
  • PCB shows 150 ohms for bias trim pot resistor
    #4 21679280
    huddslad huddslad
  • #5 21679281
    huddslad huddslad
  • 150 ohm bias resistor is acceptable; check VR2 offset adjust
    #6 21679282
    Richard Shadbolt
  • #7 21679283
    huddslad huddslad
The SC200 power amplifier build encountered issues related to bias resistor values, transistor gain differences, and component failures. The circuit diagram specifies a 150 ohm resistor in the bias circuit, while the parts list and PCB show 120 ohms; the correct value is 150 ohms as confirmed by the official circuit diagram online. The difference between 120 and 150 ohms is minor and does not significantly affect bias adjustment range due to the presence of a 1k trim pot in series. The substituted low power transistors BC556B and BC546B, which have approximately double the gain of the basic BC556 and BC546, are acceptable replacements without causing issues. Initial testing showed a small output offset voltage (~5mV) that varied slightly, but shorting the amplifier output to ground is not recommended as it can cause excessive current and component damage. The main cause of failure was identified as thermal runaway due to at least one bias transistor not being mounted flat and securely bolted to the heatsink bracket, leading to a burnt 220 ohm resistor and blown output transistor. Proper mounting and securing of driver and output transistors to the heatsink resolved the bias current stability and operational issues. Further testing with a sine wave input and oscilloscope is planned to verify distortion and noise performance.
