Using step up/step down transformers on micro hydro generator
447 7
  • Transformer voltage ratio depends on generator output
    #1 21678302
    john mantheakis
  • #2 21678303
    Elizabeth Simon
  • #3 21678304
    john mantheakis
  • Use 3 × 100 VA transformers for each phase
    #4 21678305
    David Ashton
  • 500 W transformer suggested for 12 V battery charging
    #5 21678306
    john mantheakis
  • Transformer voltage ratings and test gear recommendations
    #6 21678307
    David Ashton
  • Estimated 300 W output with 30 V alternator voltage
    #7 21678308
    john mantheakis
  • #8 21678309
    David Ashton
A floating Poncelet wheel micro hydro generator using a Windtura 750 three-phase alternator is designed to produce approximately 266-300 W per phase at around 28-40 A, with an expected voltage near 30 V per phase. The user plans to address voltage drop over a 100-meter cable run by employing three single-phase transformers wired for three-phase step-up at the generator and step-down at the load side, which includes a rectifier and a 12 V battery bank charged via an MPPT controller. Transformer ratings around 300-500 VA per phase are recommended to match the power output and improve efficiency, avoiding oversized 1 kVA units that increase magnetizing current losses. Stepping up voltage to approximately 230 V at the source reduces current and cable losses significantly, allowing the use of standard mains cable sizes (1.5 to 2.5 mm²). Careful attention is advised regarding transformer voltage ratings to prevent insulation breakdown, especially when input voltages vary. Testing equipment such as a digital multimeter and clamp meter is suggested for installation and troubleshooting in the remote Tanzanian site.
