Electronic components suitable for high vacuum in SEM chamber—volatile vs non-volatile?
432 9
What electronic components can be safely used inside a high-vacuum SEM chamber without outgassing or failing?
Use hermetically sealed components, since they are the safest choice for vacuum service and are used in aircraft, missiles, and satellites [#21678453] Replace aluminum electrolytic capacitors with hermetically sealed tantalum capacitors, and avoid plastic parts that may outgas; if necessary, remove any plastic wrapper from a metal hermetic case [#21678453] For ICs, TO-5 or ceramic packages are suitable, and you should also check the PCB material for outgassing [#21678453] Space-qualified parts are recommended as a starting point, and NASA outgassing data plus space-component vendors such as Analog Devices and ST may help identify suitable parts [#21678446][#21678447][#21678450][#21678451] If heat dissipation matters, plan for how to conduct heat away from the circuitry because vacuum removes normal convection cooling [#21678453]
  • Need low-outgassing components for SEM vacuum chamber
    #1 21678445
    Conrad Mannering
  • #2 21678446
    Rick Curl
  • Mil-spec and space-qualified parts suggested for vacuum testing
    #3 21678447
    Chip Fryer
  • #4 21678448
    Conrad Mannering
  • SEM chamber vacuum still too high for many components
    #5 21678449
    Conrad Mannering
  • #6 21678450
    Chip Fryer
  • #7 21678451
    Chip Fryer
  • #8 21678452
    Conrad Mannering
  • Hermetically sealed parts recommended for vacuum use
    #9 21678453
    PeterTraneus Anderson
  • #10 21678454
    Conrad Mannering
Designing electronic modules for operation inside scanning electron microscope (SEM) chambers requires components compatible with high vacuum environments (~7 x 10^-5 Torr). Contamination from outgassing is a critical concern. Hermetically sealed components, such as tantalum capacitors and TO-5 or ceramic IC packages, are recommended to prevent volatile outgassing and ensure reliability. Electrolytic capacitors are generally unsuitable due to potential leakage and internal pressure issues under vacuum. Space-qualified components, which are designed for extreme environments and low outgassing, are suitable candidates. Manufacturers like Analog Devices and STMicroelectronics provide aerospace and space-grade components that can withstand such conditions. Attention must also be given to PCB outgassing and thermal management, as vacuum impedes heat conduction. References to NASA outgassing data and mil-spec components provide useful guidance for material selection.
