Are Industrial Encoders Considered Inputs or Outputs in PLC Automation Systems?
225 6
  • Encoders are PLC inputs, not outputs
    #1 21678470
    Christopher Moya
  • Encoders are PLC inputs for position feedback
    #2 21678471
    Aubrey Kagan
  • Incremental encoders generate quadrature outputs
    #3 21678472
    Rick Curl
  • Encoders as position feedback and user inputs
    #4 21678473
    David Ashton
  • Incremental and absolute encoder disk patterns
    #5 21678474
    Christopher Moya
  • #6 21678475
    David Ashton
  • Incremental versus absolute encoder disk patterns
    #7 21678476
    David Ashton
Industrial encoders in PLC automation systems are considered input devices. They provide precise position and speed feedback by generating signals that the PLC reads to determine the mechanical device's status. Encoders are not outputs; rather, they are often mechanically coupled to outputs such as motors to supply positional data. There are two main types of encoders: incremental and absolute. Incremental encoders typically use a disk with radial spokes and generate quadrature signals (two square waves 90 degrees out of phase) to indicate speed and direction. Absolute encoders have disks with multiple bands of light and dark squares, each read by separate sensors to provide a unique code representing the exact shaft position. Incremental encoders are commonly used for speed and direction detection, while absolute encoders provide precise position information without needing a reference point. Encoders cannot function as timers but can be used in software to detect position limits or trigger events when a set value is reached. Limit detection is usually implemented in software or with separate sensors. Common encoder technologies include mechanical, optical (using LEDs and phototransistors), and magnetic (using Hall effect sensors). Examples of encoder applications include precise linear motion control in printers and user interface controls like rotary knobs on oscilloscopes.
