PLC- what do we connect to analogue inputs and what to digital inputs?
lukas198820 1146 1
  • #1 17777800
    lukas198820
    Help: 6
    Rate: 335
    What do we connect to analogue inputs in home automation and what do we connect to digital inputs?
    How do you check whether a door is open or closed without a reed switch?
    bubu1769
    Help: 1177
    Rate: 2374
    Analogue inputs can be used to connect all kinds of sensors for temperature, humidity, sunshine, wind speed, etc.
    Digital inputs can be used to confirm that doors are closed, windows are closed, lights are switched off, a flood sensor.
    As for the doors, is there an option of mounting a reflector for a laser sensor or something similar on them?
