Difference Between Pulsed and Unpulsed RF Waves in Gigahertz Solutions Meters
345 10
What is the difference between pulsed and unpulsed RF radiation, and how does a meter distinguish them?
Pulsed RF means the transmitter’s output power is switched on and off in bursts, while unpulsed RF is a continuous carrier; the frequency can stay the same in both cases, but in pulsed mode the power drops to zero (or near zero) between bursts [#21678626] [#21678630] AM/FM broadcast radio is an example of continuous, unpulsed RF, while radar and ASK-type data links are pulsed because they transmit energy only during the “on” times [#21678626] In the ham-radio Morse example, the oscillator can keep running continuously, but the antenna output is keyed on and off, so the external signal is pulsed even though the oscillator is steady [#21678628] [#21678630] So the meter’s “quantitative differentiation” is about measuring intermittent pulse power versus continuous radiation, not about whether the carrier frequency itself is changing [#21678626] [#21678630] DC can also be pulsed or unpulsed; for example, a battery feeding a lamp is unpulsed DC, while PWM or serial data are pulsed DC [#21678626]
  • Clarifying pulsed versus unpulsed RF radiation
    #1 21678625
    Len Murray
  • Explains pulsed RF as radar and ASK signals
    #2 21678626
    David Ashton
  • Clarifying pulsed versus carrier frequency for EMF experiments
    #3 21678627
    Len Murray
  • #4 21678628
    Elizabeth Simon
  • #5 21678629
    Len Murray
  • Pulsed RF means intermittent output power, not frequency
    #6 21678630
    David Ashton
  • Pulsed RF keeps the carrier frequency unchanged
    #7 21678631
    Len Murray
  • #8 21678632
    David Ashton
  • Hydrophilic surface exclusion zone measured at 200 mV
    #9 21678633
    Len Murray
  • #10 21678634
    David Ashton
  • EZ water claims require direct microelectrode measurement
    #11 21678635
    Len Murray
The discussion clarifies the difference between pulsed and unpulsed radio frequency (RF) waves, particularly in the context of Gigahertz Solutions RF meters. Unpulsed radiation refers to continuous wave signals such as FM or AM radio transmissions, where a constant carrier frequency is modulated in amplitude or frequency. Pulsed radiation, exemplified by radar systems, involves transmitting short, high-power bursts of RF energy followed by intervals of no transmission to allow echo detection. The fundamental carrier frequency remains constant in both cases; pulsing affects the output power intermittently rather than the frequency itself. For example, microwave ovens use magnetrons operating at about 2.5 GHz continuously or in long pulses by switching power on and off. Pulsed mode means the RF power output is intermittent, not the frequency. The conversation also touches on practical applications and experimental setups involving microwave frequencies and water interactions, referencing Gerald Pollack’s research on exclusion zone (EZ) water. The Gigahertz Solutions meters’ ability to quantitatively differentiate pulsed from unpulsed radiation is valuable for accurately measuring diverse RF emissions.
