Signal generators – how to transmit microwave frequencies into water
261 6
  • Clarifying microwave transmission and generator options
    #1 21678368
    Len Murray
  • Need to choose frequency range and power level
    #2 21678369
    Rick Curl
  • #3 21678370
    Len Murray
  • Laser and prism options for specific wavelengths
    #4 21678371
    Rick Curl
  • #5 21678372
    Len Murray
  • Water’s dielectric constant changes wavelength and causes reflection
    #6 21678373
    Max Maxfield
  • 430 MHz works better than 900 MHz underwater
    #7 21678374
    Adam Carlson
The discussion addresses the challenge of transmitting microwave frequencies into water for experimental purposes, specifically targeting water's exclusion zone phenomena. Microwave frequencies span a broad range (300 MHz to 300 GHz), and no single signal generator covers the entire spectrum. Low-power microwave signal generators are commonly available, but higher power levels require microwave power amplifiers, which introduce safety concerns. Transmission into water typically involves using horn antennas connected via short coaxial cables to minimize attenuation. The significant dielectric constant of water (~80) causes wavelength shifts and strong surface reflections, complicating signal penetration. Saltwater's conductivity further increases signal attenuation. Practical radio frequency propagation in fresh water is feasible up to approximately 430 MHz, with effective communication depths of 3-5 feet reported in radio-controlled submarine applications; frequencies near 900 MHz experience excessive attenuation. For infrared and visible light spectrum experiments, tunable lasers or white lasers combined with prisms can provide selectable wavelengths, though these are separate from microwave signal generators. Incandescent lamps with prisms offer a low-cost alternative for visible light wavelength selection.
