Controlling 200-600V 30-60A Solenoid With 5V Signal: MOSFET or TRIAC Alternatives?
309 6
  • Need for a cheap 600 V 5 V solenoid switch
    #1 21678899
    viktar pisarchyk
  • Suggests dual IGBT switch with optocoupled driver
    #2 21678900
    Rick Curl
  • Rectified AC drive and kickback cause failures
    #3 21678901
    viktar pisarchyk
  • Hybrid relay approach to prevent arcing during switching
    #4 21678902
    Elizabeth Simon
  • Capacitor commutation for turning off dc thyristors
    #5 21678903
    Conrad Mannering
  • #6 21678904
    viktar pisarchyk
  • #7 21678905
    Rick Curl
The discussion addresses controlling a high-voltage (200-600V), high-current (30-60A) solenoid using a low-voltage (5V) control signal. The original method employs solid state relays (SSRs) with bridge rectifiers but is costly and prone to failure due to under-rating and lack of kickback protection. Alternatives considered include using triacs, which are unsuitable for DC due to their inability to turn off without AC zero crossing, and power MOSFETs, which require robust diode protection against coil inductive kickback. A proposed solution involves using two IGBTs with internal inverse diodes connected in series with the load, driven by optocouplers, combined with transient voltage suppression devices such as varistors or TVS diodes for protection. The solenoid is powered by full-wave rectified AC, resulting in a pulsating DC voltage ranging from 0 to ~260V, occasionally up to 440V, with rare peaks near 600V. Failures in SSRs are linked to rapid switching and insufficient power rating. Additional suggestions include hybrid relay designs combining electromechanical relays with solid state components to reduce arcing, and capacitor commutation circuits for thyristors to enable DC turn-off in inductive loads. Protection components like Bourns MOV-20D391K metal oxide varistors are recommended for transient suppression. Experimental prototyping with multiple approaches is underway to validate these concepts for potential larger-scale application.
