How to Use Transistors to Switch Electromagnet Voltage from 12V to 9V?
291 9
How can I reduce a 12V battery supply to about 9V for an electromagnet using a transistor?
A transistor alone is not a good way to drop a 12V electromagnet supply to 9V; you either need a switch-mode power supply or a pass/emitter-follower stage, and you must know the solenoid current to size the parts and check transistor dissipation [#21685411] If the electromagnet can work at a lower voltage and the current is low enough, a variable resistor or emitter follower with an adjustable resistor can be used, but power loss in the pass transistor may make it impractical [#21685411] Put a diode across the solenoid to clamp the flyback voltage when the power is turned off [#21685411] If the turn-off time is critical, a normal silicon diode is not ideal because it slows the decay of the magnetic field [#21685414] In that case, use an RC snubber or a zener diode instead to let the back-EMF rise higher and reduce turn-off time [#21685414]
  • #1 21685410
    bigpablo
  • Need solenoid current to size regulator
    #2 21685411
    Richard Gabric
  • #3 21685412
    Giovanni Di Maria
  • #4 21685413
    bigpablo
  • #5 21685414
    Richard Gabric
  • #6 21685415
    bailey425
  • #7 21685416
    Sambath Kumar
  • #8 21685417
    Maurizio Di Paolo Emilio
  • Relay anti-chatter capacitors and back-emf protection
    #9 21685418
    Sambath Kumar
  • #10 21685419
    Sambath Kumar
The discussion addresses controlling the voltage supplied to an electromagnet from a 12V battery, aiming to switch it down to 9V using transistors. Key considerations include the solenoid current draw, as this affects the choice of components and power dissipation in the transistor. A simple variable resistor or an emitter follower circuit with a variable resistor can adjust output voltage, but power dissipation and heat must be managed. Protection against back EMF generated by the solenoid is critical; diodes across the coil are recommended, with suggestions to use RC snubbers or zener diodes for faster turn-off times. A logic-based switching method using multiple gates to select between 12V and 9V was proposed. Practical circuit designs include relay driver transistors with polarity protection diodes (preferably Schottky diodes like the MBR1545 for low forward voltage drop) and capacitors (47–100 µF, 25–40V rating) to prevent relay chatter. The relay coil current should be limited to about 120–150 mA. Schematics were referenced but not included in the text. Overall, the solution involves careful transistor selection, voltage regulation methods, and protective components to safely switch the electromagnet voltage between 12V and 9V.
