How to calculate gain for the following LPF Op Amp circuit? what value need to be changed to get mor
327 9
  • #1 21679012
    Kris K
  • Gain set by resistor ratio R53/R56
    #2 21679013
    David Ashton
  • MFB gain changes require redesigning cutoff and Q
    #3 21679014
    Richard Gabric
  • #4 21679015
    Kris K
  • #5 21679016
    Kris K
  • Need more details on DAC output and bandwidth
    #6 21679017
    Richard Gabric
  • #7 21679018
    Kris K
  • Use FilterPro to design the 2nd-order LPF
    #8 21679019
    Richard Gabric
  • #9 21679020
    Richard Gabric
  • #10 21679021
    Kris K
The discussion addresses how to increase the gain of a low-pass filter (LPF) operational amplifier (op amp) circuit, specifically a multiple feedback (MFB) filter. The original circuit has a gain of 1, determined by resistor ratios (R53/R56), with equal resistor pairs (R53=R223 and R56=R67) at 2.4 kΩ each. Increasing gain involves changing these resistor values, for example doubling R53 and R223 to 4.8 kΩ to achieve a gain of 2, while maintaining resistor matching with 1% tolerance for stability. However, altering resistor values affects the filter’s cutoff frequency (fc) and quality factor (Q), requiring recalculation of capacitors (C34, C35) to preserve filter characteristics. The user’s input is a 3.3 V peak-to-peak signal from a TVL320aic34 DAC operating at 96 kHz, and the filter is designed as a two-pole Bessel low-pass with a -3 dB bandwidth at 100 Hz for a gyro sensor motor drive application. Recommendations include using Texas Instruments’ FilterPro software to redesign the filter with desired gain and frequency response, verifying component tolerances, and avoiding ceramic capacitors where DC is present due to capacitance variability. The output voltage swing target is ±5 V, and the inversion of the output relative to input should be considered in the design.
