Robust Home-Control System Design for Tamper-Resistant Door Sensor Connections
312 6
  • Request for tamper-resistant door sensor wiring ideas
    #1 21679200
    Mungo Henning
  • Use TVS protection and pulse-response signaling
    #2 21679201
    Elizabeth Simon
  • AC sensing with window detection for tamper resistance
    #3 21679202
    Mungo Henning
  • Wireless sensor recommendation for harsh environments
    #4 21679203
    vaibhav sharma
  • Square-wave biasing for tamper detection
    #5 21679204
    Elizabeth Simon
  • #6 21679205
    Mungo Henning
  • #7 21679206
    Mungo Henning
The discussion focuses on designing a robust home-control system for door sensor connections that can resist tampering such as short-circuits, open-circuits, and exposure to mains electricity surges. Key recommendations include protecting signal lines with transient voltage suppression (TVS) diodes and series resistors, and employing opto-isolators at sensitive circuit ends to prevent damage. A communication protocol involving periodic pulse exchanges between sensor and control units is advised to detect faults or tampering. Using an AC signal source, such as a square wave generated by drivers like the 422 or 485, can prevent electrolysis on switch contacts and enable a "window" detection system that distinguishes open-circuit, short-circuit, and valid signal states by monitoring voltage levels. Wired connections are preferred over wireless for reliability and security, although wireless industrial sensors with long-range capabilities were suggested but rejected by the original poster. The design aims for simplicity while ensuring resilience against environmental and malicious interference.
