Identifying 4-Memory CW Keyer with TTL Chips, 555 Timer, and Unmarked 40-Pin IC
342 13
What is this 4-memory electronic keyer with TTL chips, a 555 timer, and an unmarked 40-pin IC, and what does the 40-pin chip do?
It is very likely a homebrew memory keyer, probably for RTTY rather than CW, built around a Standard Microsystems COM2017 40-pin UART and five MK4102N-1 1K static RAMs [#21679234][#21679235] The 40-pin part was identified from its marking as “19-10459-01 SMC 7815F COM 2017,” which matches an old UART rather than a microcontroller [#21679232][#21679234] The 555 timer is used to generate the UART clock; the reported 960 Hz square waves on pins 17 and 40 fit the expected 16× baud-rate clocking [#21679231][#21679235][#21679236] Power appears to come in as 12 V and is regulated down by a 7805 to +5 V, while the “+3 V” seen on pin 2 is not the expected -12 V from some UART versions and should be traced before applying any negative supply [#21679232][#21679235][#21679236] The lack of a manufacturer logo and the use of socketed chips on perfboard also point to a carefully built one-off project [#21679231][#21679234]
  • #1 21679226
    Geoff Theasby
  • #2 21679227
    David Ashton
  • #3 21679228
    Geoff Theasby
  • #4 21679229
    Elizabeth Simon
  • #5 21679230
    Geoff Theasby
  • Requesting IC markings and power details
    #6 21679231
    PeterTraneus Anderson
  • #7 21679232
    Geoff Theasby
  • #8 21679233
    Geoff Theasby
  • Diagnostic tests and chip ID suggest RTTY memory keyer
    #9 21679234
  • #10 21679235
    Geoff Theasby
  • UART pin 2 may be a -12 V supply
    #11 21679236
  • AY-5-1013 datasheet for COM2017 UART keyer
    #12 21679237
  • #13 21679238
  • #14 21679239
    Geoff Theasby
A 4-memory electronic CW keyer was examined, featuring four external connections (12 VDC input, ground, and pins with +3 V and +8 V always on), multiple TTL chips, a 555 timer, and an unmarked 40-pin IC. The 40-pin IC was identified as a Standard Microsystems Corporation (SMC) COM 2017, a 40-pin UART chip dating from 1978, likely a pre-microcontroller serial communication device. The keyer board is a high-quality homebrew design on perfboard with socketed chips, including five MK4102N-1 1k static RAM ICs. Measurements confirmed pin 1 of the UART at +5 V, pin 3 at ground, and pin 2 at +3 V instead of the expected -12 V, likely due to level-shifting circuitry. The 555 timer is used to generate a 960 Hz square wave clock signal at pins 17 and 40 of the UART. The device operates from a 9 V to 12 V supply regulated by a 7805. The discussion included references to datasheets for the SMC COM 2017 and related UARTs such as the Intersil HD6402 and General Instrument AY-5-1013, suggesting the keyer is a vintage design from the late 1970s or early 1980s. Recommendations included tracing circuitry before applying any negative voltages and preserving documentation inside the device for future reference.
TL;DR: Forum sleuthing identifies the unmarked 40‑pin IC as an SMC COM2017 UART; a 960 Hz clock was observed, and “UART pins 17 and 40 are clocks at 16× the RTTY baud rate.” [Elektroda, Anonymous, post #21679236]
What exactly is this box—CW keyer or RTTY memory keyer?
Evidence points to a hardware RTTY memory keyer: an SMC COM2017 UART, 555‑derived 16×‑baud clock, and multiple 1K×1 SRAMs. [Elektroda, Anonymous, post #21679234]
How do I confirm the 40‑pin IC is a COM2017 UART?
Read the package text: “19‑10459‑01 SMC 7815F COM 2017.” Then verify typical UART pin behavior and clocks at pins 17 and 40. [Elektroda, Anonymous, post #21679232]
How can I test it safely with a multimeter and scope?
With power off, pin 3 to ground shows ~0 Ω. Power on: pin 1 ≈ +5 V; pin 17 and pin 40 show ~960 Hz square waves. [Elektroda, Anonymous, post #21679235]
Why is there +3 V on UART pin 2 instead of −12 V?
PMOS UARTs often used −9 to −12 V rails, but this build shows +3 V due to level‑shifting. Trace before applying −12 V. [Elektroda, Anonymous, post #21679236]
What’s the correct way to try −12 V on pin 2 if needed?
Only after tracing the circuit, inject −12 V through a 1 kΩ series resistor to limit current while monitoring draw. [Elektroda, Anonymous, post #21679236]
How is the timing generated—do I need to set baud rate?
A 555 provides the 16× baud clock; a trimpot sets the oscillator so the UART derives the baud rate. [Elektroda, Anonymous, post #21679231]
What memory chips are installed and what do they do?
Five MK4102N‑1 1K×1 static RAMs store keyed characters or macros for transmit memory functions. [Elektroda, Anonymous, post #21679235]
What connections exist on the D‑sub and what are they for?
The 9‑way D‑type exposes +12 V input, ground, and pins carrying +3 V and +8 V rails that remain active. [Elektroda, Anonymous, post #21679226]
How do I verify this is RTTY‑oriented rather than a paddle CW keyer?
RTTY needs a UART and 16×‑baud clock; CW paddle keyers don’t. The measured 960 Hz clock supports RTTY operation. [Elektroda, Anonymous, post #21679234]
What is a UART in simple terms?
A UART is a Universal Asynchronous Receiver‑Transmitter that converts parallel data to serial and back, handling start/stop framing. [Elektroda, Anonymous, post #21679234]
What is RTTY, and why use a UART for it?
RTTY is teleprinter data over radio. A UART matches its asynchronous serial format, enabling stable baud timing and framing. [Elektroda, Anonymous, post #21679234]
How do I power the unit without damage?
Feed 9–12 V into the input traced to the 7805. Confirm +5 V rail first; avoid forcing −12 V until traced. [Elektroda, Anonymous, post #21679232]
Can you give me a quick test procedure to identify the board?
  1. Power off: check pin 3 to ground ≈ 0 Ω.
  2. Power on: verify pin 1 ≈ +5 V.
  3. Scope pins 17 and 40 for ≈ 960 Hz. “UART pins 17 and 40 are clocks at 16× the RTTY baud rate.” [Elektroda, Anonymous, post #21679236]
What edge cases could trip me up during debugging?
Applying −12 V to pin 2 without tracing can damage parts. Use a 1 kΩ series resistor and check current first. [Elektroda, Anonymous, post #21679236]
Is this a homebrew or commercial build?
Socketed TTL on perfboard with quality panel lettering suggests excellent homebrew construction rather than a mass‑produced unit. [Elektroda, Anonymous, post #21679231]
