Can I Splice Tethered Joystick to Skid Steer Electric Over Hydraulic Controls for Backhoe?
261 8
  • Wiring a tethered joystick and safety controls
    #1 21679716
    Brian Michaud
  • Paralleling a second joystick across switch controls
    #2 21679717
    Rick Curl
  • Need joystick type and circuit diagram
    #3 21679718
    David Ashton
  • Suggests tapping the in-cab electronic throttle lever
    #4 21679719
    Brian Michaud
  • Suggesting an in-cab tethered backhoe control setup
    #5 21679720
    Brian Michaud
  • Suggesting a prewired Case joystick retrofit
    #6 21679721
    Brian Michaud
  • Suggest posting the joystick and valve schematic
    #7 21679722
    Rick Curl
  • #8 21679723
    Brian Michaud
The discussion centers on modifying a skid steer's electric over hydraulic 4-way joystick control system to enable remote operation of a backhoe attachment without leaving the backhoe seat. The original system likely uses switches controlling solenoid valves, but some skid steers may employ CAN bus digital controls, complicating modifications. The proposed solution involves splicing a tethered joystick connection in parallel with the existing joystick or alternatively rigging a remote joystick control within the cab. Additional safety features considered include wiring an engine kill switch and throttle control, with the latter potentially requiring an electronic actuator rather than mechanical linkage. The user is investigating the Case TR310 backhoe attachment and exploring parts diagrams and schematics to identify control system details, including the possibility of modifying the 6-spool hydraulic backhoe controls or purchasing a pre-wired Case joystick for integration. Sharing relevant schematic excerpts is encouraged to provide targeted advice, focusing on joystick switches, solenoids, and hydraulic spool valves.
