Li-ion 3S3P Charger: 3S 20A 18650 Charger PCB BMS Protection Board - Charging Module Query
HappyWhite 8007 13
Is this 3S 20A board a Li-ion charger module with over-discharge protection, or only a protection/BMS board, and can TP4056-based chargers be paralleled to increase charging current for a 3S3P or 3S4P pack?
It is not a charger; it is only a BMS/protection board for a 3-cell series pack, with balancing/protection functions, not a module that charges the pack by itself [#16419219] [#16419760] TP4056 charger boards cannot simply be connected in parallel to increase current, because a TP4056 charger is meant for one 3.7 V cell (4.2 V full) and needs its own supply capacity; one reply notes that 4 TP4056 modules can be combined into a charger delivering about 3 A [#16415492] [#16417639] A 5 V phone charger is not suitable for charging three cells in series, because a 3S pack charges to about 12.6 V, so the charger must provide a higher voltage than that [#16417639] For a single-module solution, the thread suggests looking at a proper charger with balancer, or a charger based on the LT1513 system [#16422105] Another suggested example is a ready-made LiPo charger with balancer (Redox) rather than a simple TP4056 board [#16418702]
  • Clarifying whether the board charges and supports parallel TP4056 modules
    #1 16414924
    HappyWhite
    http://www.banggood.com/3S-20A-Li-ion-Lithium...-Board-12_6V-Cell-p-1118043.html?rmmds=search
    Quick question:
    Is this board a charger module + over discharge protection (up to 20A) or only protection?
    If it is the same protection, can you suggest some charger modules? They would load the 3S3P or even 3S4P packet
    Can chargers based on the TP4056 chip (without over discharge protection) be connected in parallel, thereby increasing the charging current?
  • #2 16415492
    Adam-T
    Help: 834
    Rate: 1096
    This is a charger with a balancer, i.e. with protection for even charging of batteries connected in series.
    EDIT I am correcting my mistake, this is just a balancer.
    Can not. There are chargers made of 4 pcs TP4056 "giving" 3A on the output. Example .
  • #3 16415613
    HappyWhite
    Is what I have drawn correctly? If you couldn't suggest 2 tiles? Charging 3S 3A (or more) battery and over-discharge protection with 10-20A capacity
  • #4 16415702
    Adam-T
    Help: 834
    Rate: 1096
    Where's the drawing?
  • #5 16417447
    HappyWhite
    Okay
  • #6 16417639
    Adam-T
    Help: 834
    Rate: 1096
    Apart from (for a moment) both modules, how do you imagine charging with a 5V phone charger three batteries connected in series, whose voltage after charging is about 12.6V?
    And now the modules: the first on the left on TP4056 is used to charge one 3.7V battery (4.2V after charging) and a maximum current of 3A. To be able to charge with such current it must be powered from a power supply with current capacity over 3A. The phone charger is too weak.
    The second module - I have already written:
    EDIT As above, I am correcting my mistake, this is just a balancer.
    Since the batteries are connected in series and after charging the voltage on them will be 12.6V, it is logical that it should be powered with a higher voltage than 12.6V
    Your drawing can be read like this: a 5V power supply powers the charger of one 3.7V battery, which charges the balancer of three batteries with a total voltage of 12.6V.
  • #7 16418244
    HappyWhite
    Okay, so I'm too stupid XDDD Will you suggest something?
  • #9 16419025
    HappyWhite
    rather a module ... for installation in a housing (portable speaker)
  • #10 16419219
    Freddy
    Help: 1394
    Rate: 2821
    You are wrong - look carefully.
    This is only a BMS for the charger.
  • #11 16419760
    Adam-T
    Help: 834
    Rate: 1096
    Actually, mea culpa. I had some darkness looking at it earlier. ;)
  • #12 16422031
    HappyWhite
    Would someone suggest some charger for Li ion 3S3P in the form of a single module and not a professional charger? I want to put it in a casing so if it is possible it can be 2 plates
  • #13 16422105
    Freddy
    Help: 1394
    Rate: 2821
    You got an offer in # 8 - the housing can be removed :) .
    You can also buy balancer and an extra charger, for example on the LT1513 system.
    • LT1513.pdf (214.91 KB) You must be logged in to download this attachment.
  • #14 16422205
    HappyWhite
    And the charger you mentioned ... If I have a 3S4P package of which every cell has an average of 2200mAh, will the charger charge the whole package in less than 9 hours?
    Maybe some charger that has a slightly higher charging current? I was hoping for 5h but I don't know if it is possible and whether I will damage the links.
    And one more thing ... what is the difference between Li-po and Li-ion? Chargers same?
The discussion revolves around the functionality of a 3S 20A Li-ion charger PCB BMS protection board. Users clarify that the board primarily serves as a balancer and does not function as a charger module with over-discharge protection. Suggestions for suitable charger modules that can handle 3S3P or 3S4P configurations are requested, with emphasis on the need for higher charging currents to reduce charging time. The TP4056 chip is mentioned, but it is noted that chargers based on this chip cannot be connected in parallel to increase current. Users seek recommendations for compact charger modules suitable for installation in portable devices, while also inquiring about the differences between Li-ion and Li-po batteries.
