How to Design a Freshwater Underwater Electrode Array for Localized mV Voltage Control
288 7
  • Need for patterned mV control in fresh water array
    #1 21679939
    L o
  • #2 21679940
    Justin Spencer Mamaradlo
  • #3 21679941
    L o
  • Need clearer requirements and separate circuit blocks
    #4 21679942
    Elizabeth Simon
  • Gold-coated PCB electrode grid for submerged mV control
    #5 21679943
    L o
  • #6 21679944
    Conrad Mannering
  • #7 21679945
    L o
  • #8 21679946
    L o
A biologist seeks to design a freshwater underwater electrode array capable of producing localized, patterned voltage changes in the range of 1-20 mV, with the ability to switch electrodes ON and OFF via external triggers and maintain activation for extended periods (hours to days). The array should be arranged in a tile-like flat configuration, possibly a hexagonal grid of circular electrodes on a gold-coated PCB, submerged at shallow depths (20-40 cm). Key challenges include ensuring circuit insulation while allowing voltage delivery, preventing electrode encrustation and metal migration in freshwater, and enabling topographical and intensity patterning of voltage outputs. Suggested solutions include using op-amp circuits with potentiometers for voltage control, DIP switches or multiplexers for electrode selection, and buffering signals with additional op-amps. Concerns about metal migration highlight the potential need for reversing current polarity periodically or adding a cleaning electrode in the tank. Conductive textile coatings were considered but may affect electric field resolution. The design must ensure durability for several days of immersion with periodic cleaning intervals.
