BEGGINER/Newbie help: Repurposing PC PSU to run mini-fridge…
339 9
How can I tell whether a 12V PC power supply is enough for a mini-fridge Peltier cooler, and can a damaged Peltier module be repaired?
A 12V PC power supply that can deliver more than 5A should be sufficient; the fact that the fridge only draws about 2.65–3A does not mean the supply is too weak, because the load determines the current draw [#21660798][#21660803] The more likely problem is the mini-fridge itself, not the PSU [#21660803] In the thread, the Peltier module was found to have a weak spot near the positive terminal, and moving the wire made it intermittently heat and cool, which points to a damaged connection/module rather than an underpowered supply [#21660804] The only repair suggestion given was to use epoxy adhesive on the damaged area [#21660805]
  • Insufficient current from PC PSU for peltier cooler
    #1 21660797
    Joey Picerno
  • #2 21660798
    DAVID CUTHBERT
  • #3 21660799
    Joey Picerno
  • #4 21660800
    DAVID CUTHBERT
  • #5 21660801
    Joey Picerno
  • Suggesting a dummy load to test PSU trip cause
    #6 21660802
    Mark Harrington
  • Mini-fridge load likely causing current draw issue
    #7 21660803
    Justin Grantham
  • Intermittent peltier connection near cracked ceramic edge
    #8 21660804
    Joey Picerno
  • #9 21660805
    DAVID CUTHBERT
  • #10 21660806
    Mark Harrington
A mini-fridge collectible Coca-Cola vending machine using a peltier/thermo-electric cooler originally powered by a 12V 5A external power supply was repurposed to run on a PC power supply. The PC PSU provided a steady 12V output but only delivered 2.65 to 3 amps, less than the original 5A rating. Both cooling and heat-dissipating fans were operational, but the peltier element failed to achieve significant temperature differentials, not cooling below room temperature. The power supply was confirmed to be functioning correctly under load, suggesting the issue lies with the peltier device. Inspection revealed a weak spot near the positive terminal on the peltier’s ceramic side, causing intermittent heating/cooling when the wire was moved. Repair suggestions included using epoxy adhesive to reinforce the damaged ceramic. The discussion emphasized that the current draw depends on the load, not the power supply, and recommended verifying the peltier’s integrity before considering power supply faults.
