Op Amp Pin Connections for Temperature Control Circuit: V+ and V- Wiring Clarification
267 5
  • #1 21680148
    NYAME EPHRAIM MECHANE
  • 741 supply pins are reversed in the instructions
    #2 21680149
    David Ashton
  • 741 op amp supply pins were transposed
    #3 21680150
    Richard Gabric
  • Recommended reading on how to read datasheets
    #4 21680151
    Max Maxfield
  • Verify op amp wiring against the datasheet
    #5 21680152
    Max Maxfield
  • Using family datasheets and diode tests to identify pins
    #6 21680153
    Justin Spencer Mamaradlo
