Why Does My 741 Op-Amp Unity Gain Buffer Not Respond to Inverting Input Pot?
282 6
  • 741 unity-gain buffer needs proper negative feedback
    #1 21682432
    Graham Rounce
  • #2 21682433
    Graham Rounce
  • #3 21682434
    Aubrey Kagan
  • Unity-gain follower cannot use inverting input pot
    #4 21682435
    Rick Curl
  • Recommended op-amp learning resources and tutorials
    #5 21682436
    David Ashton
  • #6 21682437
    David Ashton
  • #7 21682438
    georji mandela
The discussion addresses the issue of a 741 operational amplifier configured as a unity gain buffer (voltage follower) not responding to a potentiometer connected to the inverting input. The 741 is powered by ±9V supplies, with pots on both input pins and a meter on the output. The problem arises because in a unity gain buffer configuration, the inverting input is tied directly to the output, preventing the potentiometer on the inverting input from influencing the output voltage. The output voltage follows only the non-inverting input voltage. This is due to the low output impedance and the feedback connection, which forces the inverting input voltage to match the output voltage, effectively disabling the pot on the inverting input as a control input. To achieve summation or differencing of voltages, different circuit configurations are required, not a simple unity gain buffer. Additional advice includes using circuit simulators like NI Multisim for experimentation and consulting op-amp reference materials such as Texas Instruments application notes. Offset null pins were not used as high accuracy was not required.
