How Does Reversing Start Winding Reverse Single Phase Induction Motor Direction?
624 12
Why does swapping the start winding connections reverse a single-phase induction motor’s direction even though the supply is AC and its polarity keeps reversing?
The motor changes direction because its rotation depends on the relative magnetic field produced by the main and start windings, not on AC polarity alone; reversing one winding relative to the other shifts the net field to the opposite side, so the rotor starts the other way [#21680165] [#21680170] The capacitor itself is non-polarized, so reversing the capacitor by itself does nothing; what matters is which winding it feeds and the phase shift it creates between the two windings, typically about 90 degrees [#21680164] [#21680165] In AC operation both windings reverse polarity every half-cycle, but they reverse together, so the north/south poles of both windings flip while the overall field position remains the key factor [#21680172] A winding can be “reversed” by swapping its two leads, which reverses the direction of its magnetic poles relative to the other winding [#21680169] [#21680170] If the windings are internally tied together and only three wires come out, you may not be able to reverse it externally because you need access to both ends of the winding [#21680170]
  • #1 21680163
    Ashish Mathur
  • Reversing one winding changes motor direction
    #2 21680164
    David Ashton
  • #3 21680165
    Rick Curl
  • Questioning winding polarity reversal in single-phase motors
    #4 21680166
    Ashish Mathur
  • Clarifying what reversing a winding polarity means
    #5 21680167
    Ashish Mathur
  • #6 21680168
    Ashish Mathur
  • Reversing start winding flips the magnetic field
    #7 21680169
    David Ashton
  • Reversing start winding flips the motor field direction
    #8 21680170
    David Ashton
  • #9 21680171
    Ashish Mathur
  • AC polarity reversal does not change motor direction
    #10 21680172
    David Ashton
  • #11 21680173
    Ashish Mathur
  • #12 21680174
    Ashish Mathur
  • #13 21680175
    David Ashton
Reversing the direction of a single-phase induction motor is achieved by changing the relative connection of the start winding with respect to the main winding, not by reversing the polarity of the power supply, which is alternating current and inherently reverses polarity continuously. The start capacitor used is non-polarized, so reversing it alone has no effect. Instead, reversing the start winding connections changes the phase relationship between the main and auxiliary windings, effectively shifting the magnetic field orientation. This phase shift causes the motor's rotor (armature) to be attracted in the opposite direction, thus reversing rotation. Although inductors (windings) do not have polarity in AC circuits, their magnetic poles (north and south) depend on the winding direction and current flow. Reversing the winding leads to a reversal of the magnetic poles generated, which changes the net magnetic field direction despite the AC polarity reversal at 50/60 Hz. The motor typically has multiple leads (more than three) to allow such polarity reversal of windings. Diagrams illustrating instantaneous magnetic fields show how reversing the start winding polarity shifts the overall magnetic field, resulting in reversed rotor movement.
TL;DR: A 50/60 Hz single‑phase motor reverses when you swap one winding’s leads so its magnetic polarity is flipped relative to the other; “It’s the phase relationship … that determines the direction.” [Elektroda, Anonymous, post #21680165]
Why it matters: This FAQ helps DIYers and techs quickly diagnose and rewire single‑phase motors to run the direction they need, safely and correctly.
How do I reverse the direction of a single-phase induction motor?
Swap the two leads of either the start (aux) winding or the main winding—only one winding—so its connection reverses relative to the other. This flips the resultant rotating field and the rotor starts the opposite way. Do not swap both windings, or nothing changes. [Elektroda, Anonymous, post #21680164]
Why doesn’t flipping the start capacitor wires reverse the motor?
The common start capacitor in these motors is non‑polarized, so reversing only its two terminals keeps the electrical relationship the same. Direction depends on the relative orientation and phase of the start and main windings, not capacitor terminal order. [Elektroda, Anonymous, post #21680164]
What actually sets the rotation direction in a single-phase motor?
Direction is set by the phase relationship between the two windings. The capacitor shifts one winding’s voltage about 90°, creating a rotating field. As one expert put it, “It’s the phase relationship … that determines the direction.” [Elektroda, Anonymous, post #21680165]
Can a winding have its polarity ‘reversed’ in AC?
Yes—by swapping a winding’s two external leads. In AC, instantaneous polarity flips each half‑cycle, but reversing the connection swaps that coil’s north–south orientation relative to the other winding, changing the net field’s direction of rotation. [Elektroda, Anonymous, post #21680169]
AC already reverses 50/60 times a second—so why does rewiring matter?
Both windings reverse together each half‑cycle. What matters is their relative phase and orientation. Change one winding’s connection, and you shift where the resultant magnetic field points at any instant, so the rotor starts in the opposite direction. [Elektroda, Anonymous, post #21680172]
My motor has only three wires. Can I still reverse it?
Maybe not. Some motors tie one end of each winding internally, leaving only common, main, and start leads. Without separate access to both ends of a winding, you cannot reconfigure it for reverse. That motor will be single‑direction only. [Elektroda, Anonymous, post #21680170]
Do the start and main windings need the same resistance to reverse direction?
No. You can still reverse rotation by swapping one winding’s leads as long as you have access to both ends. Equal resistance isn’t required; the key is changing one winding relative to the other. [Elektroda, Anonymous, post #21680166]
What is a start capacitor in this context?
It is a non‑polarized capacitor in series with the auxiliary (start) winding. It delays the winding’s current by about 90°, producing a starting torque and a preferred rotation direction. [Elektroda, Anonymous, post #21680165]
Quick how‑to: What are the steps to wire for reverse?
  1. Identify the two start‑winding leads (or two main‑winding leads) in the junction box.
  2. Swap those two leads only; leave the other winding unchanged.
  3. Reassemble, apply power briefly, and verify the new rotation direction. [Elektroda, Anonymous, post #21680164]
Will swapping both windings at once change direction?
No. Reversing both windings preserves their relative orientation and phase. The resultant field remains the same, so the motor still starts the original way. Reverse exactly one winding relative to the other. [Elektroda, Anonymous, post #21680164]
Why does the rotor follow the ‘net’ field even as poles flip each half‑cycle?
The rotor’s induced magnetic polarity flips in sync with the stator. The net stator field’s spatial position remains offset by the capacitor, so the electromagnetic attraction produces torque in one consistent direction. [Elektroda, Anonymous, post #21680172]
What visual model helps explain reversal?
Imagine main poles top–bottom and start poles left–right. Swap the start leads and the start poles flip sides. The large resultant N–S axis shifts 90°, so the rotor accelerates the other way. “A picture’s worth a thousand words.” [Elektroda, Anonymous, post #21680170]
Is there a quick test statistic I can reference?
Yes: line frequency is 50 or 60 Hz. That means polarity reverses 100 or 120 times per second, yet rotation stays set by winding phase and orientation. Use this to reason about symptoms. [Elektroda, Anonymous, post #21680172]
Edge case: What failure condition prevents reversal even with access?
If the mechanical switch or internal ties permanently couple the windings so you cannot isolate both ends of one winding, reversal is blocked. Some factory‑wired designs expose only common, main, and start, limiting options. [Elektroda, Anonymous, post #21680170]
