Why does 3-phase panel power (2162W) differ from load power (1872W) with 2-pole 208V breaker?
336 18
Why does a 2-pole 208 V load on a 120/208 panel read about 15% different panel power than load power when I calculate it from the line currents and power factor?
Because that circuit is a line-to-line load, not a balanced 3-phase load, so you cannot use the averaged line current and √3 the way you would for a true balanced 3-phase calculation [#21680182][#21680184] The 208 V already comes from the 120 V phase-to-neutral system via √3, and for a load across only two phases the current is on those two phases, not all three [#21680182][#21680184] The panel meter sees an apparent power factor of cos 30° = 0.866 from the phase geometry, so the correct panel-side power is 1.732 × 208 × 6.67 × 0.9 × 0.866 ≈ 1873 W, which matches the load calculation [#21680185] In other words, the 15% mismatch came from increasing voltage by √3 while also reducing current to 2/3 by averaging all three phase currents [#21680184] For the later 277/480 example, the same idea applies: use the per-phase calculations for single-phase loads, or the 3-phase formula only when the load is actually balanced across all three phases [#21680182][#21680190]
  • Incorrect use of sqrt(3) for single 208 V load
    #1 21680176
    Paul Berry
  • Incorrect sqrt(3) use and current averaging
    #2 21680177
    David Ashton
  • Questioning whether the 3-phase formula applies to unbalanced panel loads
    #3 21680178
    Paul Berry
  • #4 21680179
    Paul Berry
  • #5 21680180
    yosoyax loketa
  • No sqrt-3 factor for direct phase loads
    #6 21680181
    David Ashton
  • Single-phase treatment of 208 V across two phases
    #7 21680182
    David Ashton
  • 1.732 factor explained as three-phase power multiplier
    #8 21680183
    Paul Berry
  • Using sum of currents for two-phase load power
    #9 21680184
    David Ashton
  • Line-to-line connection adds 0.866 power factor correction
    #10 21680185
    David Ashton
  • #11 21680186
    Paul Berry
  • Line-to-neutral loads should use phase voltage
    #12 21680187
    David Ashton
  • Single line-to-line load has no true power factor shift
    #13 21680188
    David Ashton
  • Meter agrees within 1% but 0.866 factor remains unclear
    #14 21680189
    Paul Berry
  • Phase-to-phase load appears as 0.866 power factor
    #15 21680190
    David Ashton
  • Questioning the 30° phase shift explanation
    #16 21680191
    Paul Berry
  • Phase power factor appears as 0.866 on each leg
    #17 21680192
    David Ashton
  • Non-unity power factor explains lower three-phase kW
    #18 21680193
    Paul Berry
  • Balanced 3-phase delta load cancels phase currents
    #19 21680194
    David Ashton
The discussion addresses the discrepancy between calculated three-phase panel power and measured single-load power on a 120/208V panel with a single 2-pole breaker. The initial error was applying the √3 factor incorrectly when using line-to-line voltage (208V) and averaging currents from all three phases despite only two being energized. The correct approach is to use the line-to-line voltage directly without multiplying by √3 and to use the actual current in the two energized phases without averaging. The √3 factor arises from the vector relationship between phase-to-neutral and phase-to-phase voltages in a Y-connected system and should only be applied when converting between these voltages, not when the load is connected line-to-line. Further complexity arises from the phase angle shifts in currents for single-phase loads connected across two phases, causing apparent power factors less than unity (e.g., 0.866) even for purely resistive loads. This is due to the current being in phase with the line-to-line voltage but out of phase with individual phase voltages, affecting power meter readings. Balanced three-phase loads do not exhibit this effect as phase currents balance out. The discussion clarifies the correct formulas for power calculation in single-phase and three-phase systems, the role of power factor in these measurements, and the interpretation of meter readings in such configurations.
TL;DR: With a 2‑pole 208 V load at 10 A and PF 0.90, real power is ≈1,870 W; “use the sum of currents, not the average.” The √3 factor applies only for LN↔LL conversion or balanced 3‑phase power. [Elektroda, Anonymous, post #21680184]
Why it matters: These rules prevent ~15% sizing and metering errors when you mix single‑phase and three‑phase calculations in 120/208Y and 277/480Y panels.
Quick-Facts
Why did my panel show ~2.16 kW while the 208 V load calculates to ~1.87 kW?
You mixed 3‑phase and single‑phase math. You averaged 10,10,0 A to 6.67 A and multiplied by √3, which overstates power by ~15%. For a 2‑pole 208 V load: P = 208 × 10 × 0.90 ≈ 1,872 W. [Elektroda, Anonymous, post #21680177]
When should I use the √3 factor in power calculations?
Use √3 when converting between line‑to‑neutral and line‑to‑line quantities, or when using the balanced 3‑phase formula P = √3 × V_LL × I_line × PF. Do not apply √3 to a single 2‑wire 208 V load. [Elektroda, Anonymous, post #21680185]
How do I compute kW for a single 208 V line‑to‑line load from a 120/208Y panel?
Treat it as a 2‑wire circuit. Use P = V_LL × I × PF. Example: 208 V × 10 A × 0.90 ≈ 1.87 kW. “Don’t assume 3‑phase if you have one voltage across one load.” [Elektroda, Anonymous, post #21680182]
Why does a resistive line‑to‑line load show PF ≈ 0.866 on the phases?
The phase currents are 30° out from each phase voltage when the load sits across two phases. Meters per phase “see” PF ≈ cos30° = 0.866, even though the load itself is resistive. [Elektroda, Anonymous, post #21680184]
Can I average phase currents to estimate 3‑phase panel kW?
No. Averaging hides which phases carry load. Use per‑phase power sums (V_LN × I_phase × PF_phase) or the true 3‑phase formula only when the load is balanced. [Elektroda, Anonymous, post #21680184]
How do I compute kW on an unbalanced 120/208Y panel with only line‑to‑neutral loads?
Sum per‑phase powers: P_total = 120 × (I_A + I_B + I_C) × PF_avg (if similar PFs). Example from the thread: 5.8 + 2.7 + 7.4 = 15.9 A → 120 × 15.9 = 1,908 W; with PF 0.88 → ≈1,679 W. [Elektroda, Anonymous, post #21680181]
Where does neutral current come from if most branch circuits are line‑to‑line?
Unbalanced phase loading creates neutral current at the panel. Vector sums of phase currents can yield several amps even with no neutral on a given branch. A worked example computed ~3.62 A neutral from phase values. [Elektroda, Anonymous, post #21680184]
Do the same rules apply on 277/480Y systems?
Yes. √3 relates LN to LL. A field check on a 277/480 panel showed per‑phase, neutral, and total kW agreeing with meter readings within ~1%. [Elektroda, Anonymous, post #21680189]
My meter only matches when I use 480 V and multiply by √3—why?
The classic balanced 3‑phase form is P = √3 × V_LL × I × PF. It equals 3 × V_LN × I × PF because 3/√3 = √3. For line‑line single loads, include the 0.866 phase‑view effect if you solve per phase. [Elektroda, Anonymous, post #21680185]
Quick how‑to: verify kW on a 2‑pole 208 V branch
  1. Identify connection: line‑to‑line (no neutral) or line‑to‑neutral.
  2. Compute kW: V_LL × I × PF for L‑L; V_LN × I × PF for L‑N.
  3. Cross‑check: per‑phase meters may show PF ≈ 0.866 for L‑L resistive loads. [Elektroda, Anonymous, post #21680184]
What’s the error if I treat a single 2‑pole 208 V load as balanced 3‑phase?
About 15.5% high. Averaging 10,10,0 A gives 6.67 A, then multiplying by √3 yields a 1.155 factor versus the true case. [Elektroda, Anonymous, post #21680177]
Will a utility penalize for this "apparent" low PF on line‑to‑line resistive loads?
With a balanced 3‑phase delta load, the ±30° phase effects cancel, so PF appears unity. Utilities typically bill by real kW; panel kW can be computed correctly by summing per‑phase powers. [Elektroda, Anonymous, post #21680194]
What formula should I memorize for balanced 3‑phase power?
P = √3 × V_LL × I_line × PF. It’s equivalent to 3 × V_LN × I_line × PF, linked by V_LL = √3 × V_LN. Use it only for balanced 3‑phase loads. [Elektroda, Anonymous, post #21680185]
Edge case: can a PF meter mislead on a single L‑L resistive load?
Yes. Per‑phase displays may report ≈0.866 PF, even though the load is purely resistive. Quote: “It’s not a true power factor, but it’s what it would look like.” [Elektroda, Anonymous, post #21680190]
What did the real‑world meter check show on the 277/480 panel?
Panel calculation (kW), three individual 277 V phase calculations, and neutral current matched the meter within ~1% before/after a breaker change. [Elektroda, Anonymous, post #21680189]
