Best Practices for Connecting Commons and Grounds in Multiple DC Power Supplies
981 7
  • Keeping multiple DC supplies isolated by default
    #1 21680265
    Justin White
  • Possible unintended supply ties through driver paths
    #2 21680266
    Rick Curl
  • Clarifying isolated supplies, common, and earth ground
    #3 21680267
    Justin White
  • Grounding and return-path issues in DC supplies
    #4 21680268
    Richard Gabric
  • Check stepper driver common returns with ohmmeter
    #5 21680269
    Elizabeth Simon
  • Optically isolated driver inputs need no 24 V common tie
    #6 21680270
    Justin White
  • Assessing isolation in power supplies and stepper drivers
    #7 21680271
    Justin White
  • Optically isolated driver allows separate supplies
    #8 21680272
    Elizabeth Simon
The discussion addresses best practices for connecting commons and grounds in systems using multiple switching DC power supplies. It highlights that there is no universal rule; however, commonly one side (ground or common) is tied together when multiple supplies are used, especially if subsystems communicate. Isolation between supplies can be beneficial to reduce noise, but if signals cross between subsystems, proper isolation or common referencing is necessary to avoid ground loops or unintended current paths. The distinction between "common" (supply reference) and "ground" (earth reference) is emphasized, noting that isolated supplies may float without earth connection. Optical isolation in signal paths, such as in stepper motor drivers with optically isolated inputs, allows supplies to remain isolated without tying commons together. Assessing internal supply connections is challenging without manufacturer documentation, but verifying isolation and common returns with an ohmmeter or datasheets is recommended. EMC considerations, ground loops, and safety hazards are important factors in designing common and ground connections in multi-supply systems.
