Improving Power Factor at Fuji Intake with Local Generator at 4 MW, PF Above 0.85
186 7
  • Generator voltage and capacitor switching affect intake PF and frequency
    #1 21680280
    Evan D
  • #2 21680281
    Jamie Oliver
  • #3 21680282
    Rick Curl
  • #4 21680283
    Neena Ahuja
  • #5 21680284
    Evan D
  • #6 21680285
    Evan D
  • #7 21680286
    Evan D
  • #8 21680287
    Evan D
The discussion concerns improving the power factor at the Fuji industrial plant intake, which is supplied by a 22-kV feeder from node SPG connected to the utility system PSO. The plant load and generation details include PSO with 24 MW and 12 Mvar, SPG with 6 MW and 4 Mvar, and node FPP with 5 MW and 3.3 Mvar. The local generator at node EG1 produces 4 MW at a 0.94 lagging power factor, synchronized to PSO, with the 22-kV network stepped down to 3.3 kV at nodes G3.3 and EG1. The power factor at Fuji intake is below 0.85, and the question is how to raise it above 0.85 while maintaining the local generator output at 4 MW. Proposed options include adjusting the operating voltage or frequency of the local generator. One suggestion mentions using a frequency conversion power supply to transform the AC power supply waveform, implying frequency adjustment could influence power factor. However, no definitive solution or diagram was provided, and further technical details or system diagrams are requested for precise recommendations.
