Will a Bulb Light Up or Short Circuit if Connected to Two Wires of the Same Phase?
588 8
  • #1 21680385
    schnem worne
  • Same-phase wires give zero voltage difference
    #2 21680386
    Rick Curl
  • Water analogy for same-phase bulb connection
    #3 21680387
    Max Maxfield
  • #4 21680388
    schnem worne
  • #5 21680389
    Rick Curl
  • #6 21680390
    schnem worne
  • #7 21680391
    Rick Curl
  • #8 21680392
    schnem worne
  • Bulb lights only with phase-to-neutral connection
    #9 21680393
    Rick Curl
When a bulb is connected to two wires of the same electrical phase and voltage, the voltage difference between these wires is zero, resulting in no current flow and the bulb not lighting up. This configuration does not cause a short circuit because both wires share the same potential at all times, moving synchronously through positive and negative half-cycles. The bulb requires a voltage difference between its terminals to allow current flow and illumination. Analogously, this is like two water tanks connected by a pipe and fed from the same source—no flow occurs between them due to equal pressure levels. If the bulb is connected with one wire from the phase and the other from a different phase or neutral, the bulb will light. Diagrams illustrating multiple wires connected to the bulb show that if two wires of the same phase are connected to the same terminal, closing a switch across them does not affect the bulb's state. Thus, powering a bulb from two wires of the same phase results in the bulb remaining off without causing a short circuit.
