Repurposing Reillo Dialogvision 1500VA UPS as Inverter Using IR2153 or TL494 Driver?
582 11
Can I repurpose a failed Reillo Dialogvision 1500VA UPS as a battery-to-mains inverter by bypassing the processor and driving the power stage with a simple chip like an IR2153 or TL494?
Yes, but the thread suggests you should work with the UPS’s existing control IC rather than replacing everything with an IR2153 or TL494. The unit contains a KA3525A, which is similar to an SG3525, and the suggested starting point is to find its enable path and pull pin 10 (/shutdown) high; the mains-synchronization line may also need to be disconnected if you want it to run as a standalone inverter [#21680482][#21680483] The high-voltage MOSFETs are actually driven by two IR2104 half-bridge drivers, so a simple external circuit that alternately enables one side then the other with a short dead time could produce a modified square-wave output [#21680486] In this arrangement, the KA3525A still regulates the 300–325 VDC bus, so separate AC voltage feedback may not be needed, although waveform stability and correct timing remain concerns [#21680484][#21680486] One contributor also found that a failed FET was the real fault in one unit, and replacing it restored most of the functionality, which suggests the power stage is salvageable and worth testing further before redesigning the whole inverter [#21680487]
  • Using IR2153 or TL494 to drive UPS MOSFETs
    #1 21680481
    Edward Chase
  • KA3525A controller likely only needs enable line
    #2 21680482
    Edward Chase
  • #3 21680483
    Elizabeth Simon
  • Suspects high-frequency transformer and 300V DC bus stage
    #4 21680484
    Edward Chase
  • #5 21680485
    Elizabeth Simon
  • Modified square-wave inverter using IR2104 drivers
    #6 21680486
    Edward Chase
  • #7 21680487
    Edward Chase
  • #8 21680488
    James754 James
  • #9 21680489
    James754 James
  • #10 21680490
    Frances ytruyiy
  • #11 21680491
    Frances ytruyiy
  • Promotional PV inverter manufacturer pitch
    #12 21680492
    Senergy TEC
The discussion centers on repurposing two vintage 2006 Reillo Dialogvision 1500VA UPS units with faulty control processors but intact power electronics, into simple battery-to-mains inverters. The original complex control circuitry, including USB communication, battery charging, LCD display, and mains synchronization, is considered for removal. The user explores using inverter driver ICs such as the IR2153 or TL494 to directly drive the MOSFETs, potentially with intermediate driver transistors, though the existing IR2104 half-bridge drivers may suffice. The UPS contains a KA3525A PWM controller chip, similar to the SG3525, which manages a high-power, EMC-compliant inverter stage with parallel MOSFETs and chokes. The user investigates the enable (/shutdown) pin on the KA3525A to activate the inverter function independently of mains synchronization. The power stage includes two pairs of high-current MOSFETs driven by IR2104 half-bridge drivers, producing a modified square wave output from a 300-325 VDC bus, which is then converted to 230 VAC. The transformer in the UPS likely operates at high frequency (kHz) rather than 50 Hz, consistent with a switched-mode power supply design. The user considers programming a PIC microcontroller to generate appropriate gate drive signals with PWM to approximate a sine wave, acknowledging limitations of the MOSFET bridge in producing stepped sine waves. Fault diagnosis revealed a failed MOSFET in one unit, and replacement restored most functionality, enabling further waveform analysis with an oscilloscope. The discussion highlights challenges in timing and waveform generation without the original processor and the potential to simplify the inverter control by leveraging existing driver ICs and power components.
TL;DR: Converting a Reillo Dialogvision 1500 VA UPS is doable; “1500VA UPSs” already include inverter-stage hardware you can reuse. [Elektroda, Anonymous, post #21680481]
Why it matters: This FAQ helps repairers repurpose failed UPS units into stand-alone 230 VAC inverters safely and efficiently.
Can I repurpose this Dialogvision 1500VA UPS as a basic inverter with IR2153 or TL494?
Yes. The unit already has inverter‑grade power electronics. Builders considered replacing control with simple drivers like IR2153/TL494, while bypassing USB, charger, and LCD. Reuse the existing MOSFET stage and transformer path where practical. [Elektroda, Anonymous, post #21680481]
Where is the KA3525A enable/shutdown pin, and how do I start it?
KA3525A uses Pin 10 as /Shutdown. Pull this pin high to enable the PWM controller. Add proper dead‑time and current sensing before powering the output stage. As one contributor noted, “Pin 10 is the /shutdown.” [Elektroda, Anonymous, post #21680483]
Do I need mains synchronization for off‑grid inverter use?
No. The sync input was for utility‑tie operation. For a stand‑alone inverter, you can disable or ignore the mains sync so the PWM runs independently. This simplifies the conversion while keeping the power stage intact. [Elektroda, Anonymous, post #21680482]
What topology does this UPS likely use internally?
Evidence suggests a two‑stage design: a high‑frequency converter boosts 48 V to a ~300–325 VDC bus, then an H‑bridge makes 230 VAC. The poster flagged timing challenges if the original processor is missing. Avoid simultaneous conduction events. [Elektroda, Anonymous, post #21680484]
How are the high‑voltage MOSFETs driven, and can I make basic AC?
Two IR2104 half‑bridge drivers control the four HV MOSFETs. A simple logic circuit that alternately enables each half‑bridge, with dead‑time, produces a modified square‑wave output. As noted, they “only need a logic 1” to switch. [Elektroda, Anonymous, post #21680486]
What waveform quality should I expect after conversion?
Expect modified square‑wave unless you implement advanced PWM shaping. The IR2104/H‑bridge can be toggled for basic AC. True sine requires tighter timing and feedback, which the original processor handled. [Elektroda, Anonymous, post #21680486]
Why don’t I see 30 A PCB traces going to the ‘big’ transformer?
Because the heavy conversion appears to occur at high frequency, not 50 Hz. Current may route through smaller HF magnetics and chokes that handle the power before the 325 VDC bus feeds the H‑bridge. The 30 A observation came from tracing doubts. [Elektroda, Anonymous, post #21680484]
Is it realistic to rebuild the 230 VAC timing without the main processor?
It’s difficult. The original processor coordinates H‑bridge timing and feedback. “Getting the timing right...so all 4 don’t turn on at once” is critical. Shoot‑through will destroy FETs instantly. Consider retaining existing control where possible. [Elektroda, Anonymous, post #21680484]
How can I verify the H‑bridge is switching correctly?
Probe the IR2104 gate drive outputs with an isolated oscilloscope. Confirm alternating conduction and clean dead‑time. A user restored most functions after a FET swap and planned to scope the half‑bridge to confirm waveforms. [Elektroda, Anonymous, post #21680487]
What safety risks does the ~325 VDC bus introduce?
The DC link is lethal. Treat it as live even after power removal due to stored energy in capacitors. Use bleeders, PPE, and isolation. Build test procedures before energizing the H‑bridge. [Elektroda, Anonymous, post #21680484]
I replaced a single failed FET and most features returned—is that normal?
Yes. One report showed a different FET restored about 90% functionality before the correct parts arrived. Replace devices in matched sets where possible and re‑test with current limiting. [Elektroda, Anonymous, post #21680487]
What does the ‘AVR’ label on the transformer mean here?
It likely marks an Automatic Voltage Regulator winding or assembly within the UPS. In the teardown, the transformer was labeled “AVR,” prompting that interpretation during the repurposing discussion. [Elektroda, Anonymous, post #21680481]
What is KA3525/SG3525 in simple terms?
They are fixed‑frequency PWM controller ICs for power converters and inverters. In this UPS, the KA3525A governs the high‑power stage with feedback and drives parallel MOSFETs through downstream gate drivers. [Elektroda, Anonymous, post #21680482]
What is an IR2104 half‑bridge driver?
IR2104 is a high‑ and low‑side MOSFET gate driver. It level‑shifts logic signals to drive a half‑bridge, enabling H‑bridge AC generation when two devices are used. [Elektroda, Anonymous, post #21680486]
How‑To: Enable the KA3525A inverter stage in three steps
  1. Identify KA3525A Pin 10 (/Shutdown) on the control board.
  2. Pull Pin 10 high through a suitable resistor to enable PWM.
  3. Power the logic supply and confirm switching at the gate drive stage before connecting the load. [Elektroda, Anonymous, post #21680483]
