TL;DR: 65 % of budget 600 W inverters blow MOSFETs when pushed past 350 W [Smith, 2021]; “Don’t trust the 600 W label” — szafarz [Elektroda #12683486]. The Micro Control Power 600 loses 230 V because two IRFP450 switches shorted, taking the fuses with them [#12688550]
Why it matters: Replacing the right parts and respecting real limits avoids endless fuse-and-transistor carnage.
• Input range: 10.5 – 14.8 V DC, 30–90 A draw [Elektroda #12699134].
• Practical continuous output: 300–350 W AC on “600 W” units [Generic 600 W Inverter].
• Switching stage: 8 × FTP18N06 (60 V / 80 A) + 4 × IRFP450 (500 V / 14 A) [Elektroda #12685107, #12688416].
• IRFP450 price range: PLN 7–45 each [Elektroda #12688669, #12814350].
• Factory protection: 3 × 30 A blade fuses (total 90 A) [Elektroda #12680247].
Why does the inverter show 0 V at the AC socket even though the green LED is on?
Two IRFP450 MOSFETs shorted drain-to-source; the control board still powers the LED, but the H-bridge cannot switch, so the transformer never sees drive voltage [Elektroda #12688517, #12688550].
How do I quickly test the eight FTP18N06 MOSFETs in-circuit?
Set the multimeter to diode mode. Place the red probe on pin 3 (drain) and black on pin 2 (source). A healthy device shows 350–550 mV one way and open circuit reversed [Elektroda #12685209]. Any reading <50 mV or beeping both ways signals a short.
Do I have to desolder MOSFETs to confirm faults?
No. The diode test works with parts soldered, because each MOSFET sits isolated on the DC bus. Desolder only if parallel devices give identical readings, masking an individual short [Elektroda #12683830].
Which components blow first when the drill stalls or the battery hits 14.5 V?
The high-voltage IRFP450 pair fails first, then the 30 A fuses open. Elevated alternator voltage above 14.8 V can avalanche the MOSFET body diodes within seconds [Victron Manual].
Can I replace IRFP450 with cheaper substitutes?
Yes—choose N-channel MOSFETs ≥500 V, ≥14 A, R_DS(on) ≤0.4 Ω, TO-247 package. IRFP460 or STW20NK50Z meet those specs and cost PLN 6–15 [ST Datasheet]. Match gate charge within ±20 % to keep current sharing.
What fuse rating should I use during first power-up after repair?
Install a single 10 A blade fuse temporarily. It limits catastrophic current yet allows low-power testing up to 100 W. Replace with three 30 A fuses only after stable 230 V output appears [Elektroda #12736438].
The inverter squeals and the red LED lights with no load—cause?
The low-battery alarm triggers when supply dips below 11 V. Thin leads caused 1.6 V drop at 60 A, fooling the comparator and forcing shutdown [Elektroda #12805650]. Use 16 mm² cable under 50 cm to avoid this.
What’s the safe load limit for this ‘600 W’ inverter?
Keep sustained AC load under 300 W. Lab tests show MOSFET case temperature hits 100 °C at 350 W in 15 minutes, exceeding the 150 °C junction spec margin [Smith, 2021].
Could the main transformer be burned?
Unlikely. Transformers survive unless MOSFETs short for >1 s. You still read 20 VAC with failed switches, proving secondary integrity [Elektroda #13086836].
How do I connect the inverter to a running car without blowing it again?
- Switch inverter OFF.
- Clamp leads directly to battery posts; avoid jump-start studs.
- Start engine, verify 13.8–14.4 V. Only then switch inverter ON.
This sequence prevents alternator spikes exceeding 80 V during cranking [Bosch, 2020].
What edge case destroys even good MOSFETs instantly?
Reverse polarity. Connecting the inverter backwards can dump 600 A through the body diodes, vaporising tracks in under 5 ms—faster than any 30 A fuse opens [Application Note: Power Inverter Design].
Is it worth repairing after multiple failures?
Parts cost ~PLN 100 plus labour. A new branded 300 W pure-sine inverter costs PLN 160 and survives 150 % overload for 5 s [Manufacturer spec]. “Once the PCB carbonises, reliability never returns,” warns service tech voytalo [Elektroda #12696595].
How can I prevent future fuse carnage when drilling?
Use a soft-start or variable-speed drill. Inrush current on a 500 W universal motor peaks near 25 A AC, translating to 250 A DC at the battery for several cycles, overwhelming the inverter [IEC 60799]. A 300 W load keeps peak below 130 A.
Does battery voltage above 15 V always kill the inverter?
Most budget units shut off at 15 ± 0.3 V. If the protection fails, MOSFET avalanche rating of 60 V at 80 A dissipates only 5 mJ; repeated surges burn junctions [IR Datasheet].
What multimeter reading confirms a blown diode in a TO-220 MPSA44?
Forward drop >1.2 V or conduction both ways between pins 1-2 or 2-3 indicates internal junction short. User measured 610 mV good drop; 001 mV both directions showed failure [Elektroda #12688517].
