How long is the shelf life of the PCB? And how is the baking time temperature determined?
687 6
  • #1 21680611
    John Wilson
  • #2 21680612
    Michael Rohde
  • Low-humidity storage preferred over baking PCB
    #3 21680613
    Elizabeth Simon
  • Recommend asking the fab about shelf life and storage
    #4 21680614
    Duane Benson
  • Gold plating and desiccant extend PCB shelf life
    #5 21680615
    Richard Gabric
  • Baking removes moisture but reduces solderability
    #6 21680616
    Mike Dong
  • PCB shelf life depends on surface finish and Tg
    #7 21680617
    jason Chen
The shelf life of PCBs depends primarily on their surface finish and storage conditions. Generally, PCBs have a shelf life of up to one year if stored properly in sealed, low-humidity packaging with desiccants. Surface finishes such as HASL and immersion gold typically have a shelf life of about six months, while immersion silver and OSP finishes last around three months due to susceptibility to tarnishing and corrosion. Baking is used to remove absorbed moisture from PCBs before SMT assembly to prevent defects like delamination or PCB damage. Baking parameters depend on the PCB substrate's glass transition temperature (Tg); for example, boards with Tg 130°C are baked at approximately 150°C for 2 hours, and those with Tg 150°C at about 170°C for 4 hours. However, baking can degrade solderability and should be done cautiously, considering the finish type—OSP and immersion silver are more sensitive to baking. Multiple baking cycles do not restore solderability or fully reset shelf life. IPC standards (IPC-J-STD-003 and IPC-A-600) categorize coating durability and recommend soldering within specific timeframes to maintain quality. For long-term storage, gold-plated PCBs sealed with desiccants offer better longevity. It is advisable to consult the PCB manufacturer or supplier (e.g., ALLPCB) for specific shelf life and baking recommendations.
