Best way to protect battery powered PCB outdoors: IP65 box, conformal coating, or both?
372 10
How can I best protect a battery-powered PCB that will be installed outdoors in a humid field?
Use both an IP65 enclosure and a proper electrical conformal coating on the PCB; one reply specifically recommends coating both sides of the board and any exposed terminal contacts, and says IP65 is the minimum [#21681521] Make sure the cable entries are properly sealed with glands and sealant, because if the box is truly sealed you do not need a drip hole, while poorly sealed entries can become drip holes [#21681518][#21681519] Several replies also warn about condensation inside a sealed box, so silica gel/desiccant sachets are suggested as an extra precaution [#21681514][#21681516] Keep the enclosure out of direct sun if possible: use a white or light-colored box, or put a small roof/hat over it, to reduce heating and possible warping [#21681516][#21681519] If the box is sealed completely, desiccants can help; if you use recovered sachets, dry them first before sealing them in [#21681516]
  • Asking whether IP65 enclosure and conformal coating are needed
    #1 21681513
    Chip Fryer
  • #2 21681514
    Alan Winstanley
  • #3 21681515
    Elizabeth Simon
  • #4 21681516
    David Ashton
  • Drip holes may worsen corrosion in IP65 boxes
    #5 21681517
    Chip Fryer
  • #6 21681518
    Elizabeth Simon
  • North-facing enclosure with foil and sealed cable entries
    #7 21681519
    David Ashton
  • Conformal coating for mildly hostile outdoor PCB
    #8 21681520
    Chip Fryer
  • Recommend conformal coating for outdoor PCB protection
    #9 21681521
    Mike Hibbett
  • #10 21681522
    Chip Fryer
  • Corrosion in turret switch battery compartment
    #11 21681523
    Chip Fryer
For protecting a battery-powered PCB deployed outdoors in humid conditions, an IP65-rated enclosure is recommended as a baseline protection. Using a light-colored or white enclosure helps reduce heat buildup from sunlight, and positioning the box on the northern side or shading it can further mitigate temperature rise. While drip holes can relieve condensation, they may introduce corrosion risks if water ingress occurs, so well-sealed cable entries with silicone sealant and quality rubber washer glands are preferred. Inside the enclosure, applying a dedicated electrical conformal coating or tropicalized varnish spray on both sides of the PCB and exposed terminals is advised to prevent moisture-induced corrosion. Including desiccant sachets inside the sealed box can help control internal humidity and condensation. Care should be taken to avoid non-electrical coatings that may contain corrosive chemicals. Practical experience with IP65-rated consumer electronics shows that moisture ingress can still cause corrosion without proper conformal coating. Additional mechanical securing of cable glands with adhesives like Araldite can improve reliability in vibration-prone environments.
