Control Motor speed wirelessly through wireless frequency meter
222 8
  • #1 21680835
    Bart Allen
  • XBee radios can replace the frequency meter
    #2 21680836
    Rick Curl
  • Use frequency meter data for PWM control
    #3 21680837
    David Ashton
  • #4 21680838
    Frank Jones
  • XBee-Pro 900HP analog-to-PWM motor control link
    #5 21680839
    Rick Curl
  • #7 21680841
    tulenahati tulenahati
  • XBee-Pro 900HP radios can generate PWM control
    #8 21680842
    pamela morrow
  • #9 21680843
    movad movaduh
The discussion addresses controlling the speed of a 24V DC motor wirelessly using a frequency meter. It is suggested that the frequency meter itself may be unnecessary, as it contains a Digi XBee-Pro 900HP radio module capable of forming a long-range mesh network with analog-to-digital conversion and PWM output mapping. By configuring one Digi XBee radio to monitor an analog input and the other to output PWM, the PWM signal can be fed through a MOSFET driver and MOSFET to regulate motor speed. This approach requires using Digi's XCTU configuration utility and basic programming knowledge. Alternative wireless TX/RX modules could be used for transmitting control signals, but full duplex communication might be needed for feedback. The key components for the solution include Digi XBee-Pro 900HP radios, MOSFET drivers, and MOSFETs to convert PWM signals into motor speed control.
