How to Modify DC-DC Converter Circuit from SoloElectronica for 12V 12A Output?
351 15
How can I modify the SoloElectronica DC-DC converter circuit to provide about 12V at 12A for a wiper motor?
You cannot realistically get 12V at 12A from this circuit just by changing a few parts; it is already near its design limit, with about 100W input and roughly 95W output, so only about 10–15W more might be possible at best [#21662756] The inductor is a hard limit too: it was estimated to saturate at about 5.25A DC, so you need a different inductor with a higher DC current rating rather than more turns, because more turns increases amp-turns and can make saturation worse [#21662759][#21662765] The MOSFET gate-drive stage should also be improved by replacing IC2 with a proper 8-pin MOSFET driver such as UC27518 and, if needed, reducing the 10Ω gate resistors to around 2Ω while using suitable resistor wattage [#21662756][#21662765] One suggestion was to increase the output capacitors in proportion to the desired current increase, but that does not remove the basic power and saturation limits [#21662759] In short, if you need sustained 12A, this boost converter needs major redesign or a different converter/motor controller, not just a small component swap [#21662756][#21662765]
  • Need higher-current parts for 12 V 12 A converter
    #1 21662750
    Rafael Borowski
  • Boost circuit needs buck or flyback stage
    #2 21662751
    Earl Albin
  • #3 21662752
    Earl Albin
  • Need 12–18V boost converter with 12A output
    #4 21662753
    Rafael Borowski
  • #5 21662754
    Rafael Borowski
  • #6 21662755
    Steve Lawson
  • Power limit and driver upgrades for higher output
    #7 21662756
    Earl Albin
  • Improve component derating to solve output issue
    #8 21662757
    Kanhu Padhy
  • #9 21662758
    Rafael Borowski
  • Increase inductance margin and use MOSFET driver
    #10 21662759
    Earl Albin
  • Free schematic capture software links
    #11 21662760
    Steve Lawson
  • #12 21662761
    Rafael Borowski
  • #13 21662762
    Gary Crowell Jr
  • #15 21662764
    Rafael Borowski
  • Inductor saturation limits output current to 5.25A
    #16 21662765
    Earl Albin
The discussion centers on modifying a SoloElectronica DC-DC boost converter circuit designed for 12V to 18V output with a maximum current of 5A continuous (10A peak) to achieve a stable 12V output at 12A for driving a high-start-current 12V wiper motor in a motorized kid's electric car. The original boost converter circuit is limited by its maximum output current and inductor saturation at higher currents. Suggestions include replacing the inductor with one having a higher DC current rating and maintaining the inductance around 65µH or reducing it to increase saturation current, upgrading the MOSFET driver IC (e.g., to a dedicated 8-pin driver like the UC27518) for better gate drive and efficiency, lowering gate drive resistor values, and improving PCB trace thickness and soldering for thermal and current handling. The circuit’s output voltage potentiometer allows adjustment between 12V and 26V, but the user intends to limit it to about 15V for motor safety. Alternatives proposed include using a buck or buck-boost converter topology instead of a pure boost, or employing commercial electronic speed controllers (ESC) such as the Traxxas brushed ESC or switching to a brushless DC (BLDC) motor with a compatible controller for better performance and reliability. Free schematic capture software recommendations for redesign and PCB layout include Digikey Scheme-it, TinyCAD, DipTrace, Eagle, PCB123, ExpressPCB, and Olimex dtools. The discussion emphasizes component derating, thermal management, and proper driver selection to safely increase output current without damaging the circuit or blowing fuses.
TL;DR: The SoloElectronica boost board is capped near 100 W, and, as one expert put it, "too close to its design limits." To reach 12 V/12 A (≈144 W) for a wiper motor, use a buck/buck‑boost path, upgrade the inductor, and add a real MOSFET driver. [Elektroda, Earl Albin, post #21662756]
Why it matters: This FAQ helps hobbyists safely power 12 V motors without blowing fuses or frying inductors.
Can I get 12 V at 12 A from the SoloElectronica boost board?
Not safely. The board’s practical ceiling is about 100 W, while 12 V at 12 A needs ~144 W. An expert warned the design is already “too close to its design limits.” Use a higher‑power buck or buck‑boost stage instead of pushing this boost board. [Elektroda, Earl Albin, post #21662756]
Is this boost converter suitable for a 12 V wiper motor?
It raises voltage and cannot regulate below input. A 12 V automotive motor should see at most about 14.5 V, not 18 V. For speed control and safe voltage, use a buck or buck‑boost approach. “This circuit won’t do what you intend.” [Elektroda, Earl Albin, post #21662752]
What parts should I change to increase output current safely?
Keep the inductance near the design point and choose a core with higher DC current rating. Replace the weak MOSFET driver with a dedicated driver and reduce the gate resistor to about 2 Ω to cut switching losses. Upsize output caps in proportion to target current. [Elektroda, Earl Albin, post #21662759]
What happens if the boost inductor saturates?
When it saturates, inductance collapses and current skyrockets. One analysis shows a surge toward ~1400 A in about 12 µs—your fuse or MOSFETs will not like that. “You need to get a different inductor.” This is the classic catastrophic edge case. [Elektroda, Earl Albin, post #21662765]
Should I swap to a slo‑blo fuse to survive motor inrush?
Yes, a time‑delay (slo‑blo) fuse tolerates startup surge better than a fast‑acting type. It reduces nuisance blows during motor spin‑up while maintaining protection during sustained faults. It won’t fix undersized power electronics, but it helps with inrush. [Elektroda, Steve Lawson, post #21662755]
Will a larger fuse unlock more power from this board?
Raising the fuse to about 12 A might net only 10–15 W more, and the inductor may still saturate. The core power limit, switching losses, and magnetics set the ceiling. Consider better magnetics and a real gate driver before touching fusing. [Elektroda, Earl Albin, post #21662756]
How should I improve the MOSFET gate drive?
Replace the existing IC with a true MOSFET driver. Use a lower gate resistor (≈2 Ω) and size it to at least 0.25 W. Better drive reduces switching loss and heat, improving efficiency and margin. “Replace IC2 with a real driver.” [Elektroda, Earl Albin, post #21662756]
Any specific driver IC suggestions?
Yes. UC27518 is a solid dedicated driver option for stronger, cleaner gate transitions. Pair it with appropriate gate resistance and layout care. This shift alone can markedly reduce MOSFET dissipation at your target load. [Elektroda, Earl Albin, post #21662765]
Do I need to add a lot more output capacitance?
Increase output capacitance roughly in proportion to your planned current increase; doubling is seldom necessary. Keep ESR low and ripple current ratings high. This approach stabilizes the output without unnecessary bulk or cost. [Elektroda, Earl Albin, post #21662759]
Where can I source a suitable inductor quickly?
Check Coilcraft’s DMT series and similar gapped ferrites with the correct inductance and higher DC current rating. Distributors like Digi‑Key or Mouser stock these parts and offer parametric filters for easy selection. [Elektroda, Earl Albin, post #21662765]
What off‑the‑shelf controller can I use instead of rebuilding the converter?
A Traxxas brushed ESC can handle 12 V motors and replace complex power stages. Alternatively, swap to a BLDC motor plus controller, available for under about $60, to improve efficiency and control. [Elektroda, Gary Crowell Jr, post #21662762]
How should I set the output voltage for a car wiper motor?
Start around 15 V only for brief testing, then dial near automotive norms (~12–14.5 V). Watch current draw and temperature. Avoid sustained operation above ~14.5 V to protect the motor and wiring. [Elektroda, Rafael Borowski, post #21662754]
Any PCB tips for high current on this project?
Widen high‑current traces, add heavy solder or copper pour, and minimize loop areas. Short, wide paths reduce resistive loss and heat. These mechanical upgrades complement electronic changes for reliable operation. [Elektroda, Rafael Borowski, post #21662750]
How can I document or print the schematic and board easily?
Use free tools like Digi‑Key Scheme‑It, TinyCAD, DipTrace Freeware, Eagle, PCB123, or ExpressPCB. They support schematic capture, printing, and entry‑level PCB workflows for quick iteration. [Elektroda, Steve Lawson, post #21662760]
Is 6 A running current normal for a 12 V wiper motor?
Approx. 6 A running current is a reasonable expectation; startup current is much higher and can blow smaller fuses. Select wiring, fusing, and converters with that surge in mind. [Elektroda, Rafael Borowski, post #21662750]
Quick how‑to: What’s the minimal mod path to try safely?
  1. Replace the inductor with the same inductance but higher DC current rating.
  2. Add a dedicated MOSFET driver and lower the gate resistor to ~2 Ω.
  3. Set a 12 A fuse as an upper bound and verify thermals under load. [Elektroda, Earl Albin, post #21662756]
