Toroidal Coil Signal Propagation and Exposure at 200-3000Hz, 500-1000W, 1-6ft Elevation
711 21
How does a toroidal/vortex coil behave as a transmitter at 200–3000 Hz, and how can I estimate its field range and permissible exposure?
At 200–3000 Hz, a toroidal/vortex coil of this type will be electrically tiny, so it will not act like a normal RF antenna; it produces a mainly quasi-static magnetic/dipole field near the coil, while most of 500–1000 W is turned into heat rather than being radiated far away [#21681436][#21681434][#21681442] Its geometry mainly changes the near field; far from the coil the field tends toward a dipole pattern, and a fully toroidal 90°-tilted ring arrangement would have zero dipole field [#21681436] Because of that, there is no useful long-range “broadcast” distance to calculate here in the usual antenna sense, and a dummy load or vortex coil is a poor way to generate a controlled RF field at distance [#21681442][#21681445][#21681438] To estimate the fields, model the coil from its actual dimensions using classical electromagnetics and quasi-static coupling methods such as Neumann’s formula, or an EM-modeling package; one reply also points to segment-based coil modeling [#21681442][#21681449] For exposure/safety, measure the actual field with an RF field-strength meter and apply the relevant radio regulations; if you need a strong known field in a test volume, use a proper dipole/loop, a Helmholtz coil, plates, or put the specimen inside the coil rather than trying to radiate 15–60 ft away [#21681444][#21681450][#21681448]
  • Toroidal coil behaves as near-field magnetic source
    #1 21681432
    Donald Adams
  • Questioning toroidal coil claims and pricing
    #2 21681433
    David Ashton
  • Toroidal antennas are inefficient at 200–3000 Hz
    #3 21681434
    Elizabeth Simon
  • Need formulas for toroidal coil field calculations
    #4 21681435
    Donald Adams
  • Vortex coil behaves as a dipole at long range
    #5 21681436
    PeterTraneus Anderson
  • #6 21681437
    David Ashton
  • Dummy load recommended for transmitter testing
    #7 21681438
    Elizabeth Simon
  • Desired field range limited to 15–60 feet
    #8 21681439
    Donald Adams
  • Clarifying whether a dummy-load transmitter meets FCC limits
    #9 21681440
    Donald Adams
  • Requesting formulas to estimate coil field propagation
    #10 21681441
    Donald Adams
  • Dummy load definition and coil coupling calculation method
    #11 21681442
  • Request for coil field and induced-signal modeling
    #12 21681443
    Donald Adams
  • Recommend using a dipole or loop antenna
    #13 21681444
    Elizabeth Simon
  • Dummy load wastes power; use an antenna instead
    #14 21681445
    David Ashton
  • #15 21681446
    Elizabeth Simon
  • #16 21681447
  • #17 21681448
  • Helmholtz coil suggested for known field generation
    #19 21681450
    Richard Gabric
  • Requesting expert help to compute coil model
    #20 21681451
    Donald Adams
  • #21 21681452
  • #22 21681453
The discussion centers on the signal propagation characteristics and exposure considerations of a toroidal (vortex) coil operating in the 200-3000 Hz frequency range at power levels between 500 to 1000 watts, with coil elevation from 1 to 6 feet. The coil's geometry, consisting of multiple slightly tilted one-turn rings in series, produces a near-field magnetic dipole pattern with a vortex effect that slightly reduces dipole field strength but does not alter its shape. Due to the coil's size being much smaller than the wavelength at these frequencies, it behaves as a quasi-static source with limited far-field radiation, resulting in predominantly local, omnidirectional fields with rapid attenuation beyond approximately 15 to 60 feet. This makes it unsuitable for long-distance broadcasting but potentially useful for localized biological exposure experiments. The coil is not a dummy load; it radiates some field but with low efficiency, converting much input power to heat. For compliance with FCC regulations and controlled testing, dummy loads are recommended as they dissipate power without radiation. Calculations of field strength and propagation require electromagnetic modeling using classical antenna theory and quasi-static approximations, referencing texts such as Smythe's "Static and Dynamic Electricity" and Kraus's "Antennas." Practical modeling can be done by segmenting the coil into straight-line elements and applying Neumann's formula. Alternatives like Helmholtz coils or solenoidal coils are suggested for generating uniform, strong fields within a defined volume for biological testing. The discussion also highlights the challenge of achieving strong near fields that sharply diminish with distance and the need for specialized expertise or software for precise electromagnetic modeling.
TL;DR: A dry dummy load for testing can cost less than $100, and “This is the proper way to test transmitting equipment.” [Elektroda, Anonymous, post #21681438]
Why it matters: You want omnidirectional, short‑range fields without violating FCC rules or wasting kilowatts; this FAQ shows safer, testable paths for low‑frequency coils.
Does a toroidal or “vortex” coil radiate like a normal antenna at 200–3000 Hz?
No. At these frequencies the coil is tiny relative to wavelength, so it lives in the quasi‑static regime. It couples mainly via near‑field magnetic flux and radiates very poorly. Farther away, the pattern trends toward a weak magnetic dipole. “At these frequencies, a vortex coil makes a good dummy load.” [Elektroda, Anonymous, post #21681436]
How far will 500–1000 W at 200–3000 Hz propagate from a small toroidal coil?
Not far as radiated power. Because the coil is electrically small, most power turns into heat. Any detectable field falls off rapidly with distance in the near field (∝1/r^3 for a magnetic dipole). Expect minimal far‑field radiation despite high wattage. [Elektroda, Anonymous, post #21681436]
Is the field of a toroidal/vortex coil omnidirectional?
Close to the coil, geometry complicates the pattern. Far away, it approaches a magnetic dipole. One commenter noted these coils are about as close as you get to an isotropic radiator at such low frequencies, emphasizing low gain and broad pattern. [Elektroda, Anonymous, post #21681434]
I want a 15–60 ft exposure radius without long‑range spill—what’s the simplest setup?
Use a low‑power source into a proper dummy load for transmitter checks, and only couple intentionally to a nearby test coil. Dry dummy loads leak small RF but remain safe enough for lab work. Place your specimens near the intentional test coil, not the load. [Elektroda, Anonymous, post #21681438]
How do I calculate the magnetic field from my coil geometry?
Model the winding as many straight line segments and sum their contributions (quasi‑static approximation). This method yields the B‑field in 3D from known current and geometry, and scales to arbitrary coil shapes. Validate results with a field meter. [Elektroda, Anonymous, post #21681449]
What’s a dummy load, and why do RF engineers use it?
A dummy load converts essentially all RF power to heat so the transmitter can be tested without radiating. It protects gear, reduces interference, and simplifies compliance. “A dummy load converts ALL the RF power into heat and does not radiate at all.” [Elektroda, Anonymous, post #21681445]
What coil type gives a strong, known field around samples?
Use a solenoidal coil. It produces a strong, relatively uniform internal field and has open ends for easy insertion and removal of samples. Adjust turns, diameter, and current to hit your target B‑field. [Elektroda, Anonymous, post #21681448]
What is a Helmholtz coil, and when should I use one?
A Helmholtz coil uses two identical coils separated by their radius to create a very uniform magnetic field in the volume between them. It’s ideal for controlled biological or sensor exposure tests where field uniformity is critical. [Elektroda, Anonymous, post #21681450]
Can I push 500–1000 W in the ULF/audible range and stay within FCC limits?
High power is risky without shielding and measurement. Study applicable radio regulations before transmitting any RF, even at low frequencies. Consider screened rooms for controlled experiments and avoid unintentional radiation. Seek qualified regulatory guidance. [Elektroda, Anonymous, post #21681452]
How do I measure what my samples actually experience?
Use an RF or magnetic field strength meter near the samples. Map the field at multiple points and log current, frequency, and geometry. This confirms exposure levels and helps you tune coil placement and drive. [Elektroda, Anonymous, post #21681444]
Is the vortex coil a breakthrough for wireless power or therapy?
Skeptical views dominate the thread. Most power becomes heat at these low frequencies, and claimed benefits lack rigorous data here. One expert labeled many vortex‑coil sites as pseudoscience and urged classical EM study. [Elektroda, Anonymous, post #21681442]
What does real‑world low‑frequency efficiency look like?
One practitioner drove 20 kW audio onto a 100 km suspended cable and radiated only a few watts across the audio band. This highlights the severe inefficiency of low‑frequency radiation from electrically small structures. [Elektroda, Anonymous, post #21681450]
What’s an isotropic radiator?
An isotropic radiator emits equally in all directions and serves as a theoretical reference for antenna patterns. In this context, the tiny coil’s pattern is very broad with negligible gain, resembling that ideal at a distance. [Elektroda, Anonymous, post #21681434]
Any cost reality check before I buy fancy coils?
One poster priced 105 ft of 15 AWG enamel wire at about $30, noting large retail markups on ornamental coils. Build test coils yourself and invest in measurement tools instead. [Elektroda, Anonymous, post #21681445]
How do I quickly estimate fields and verify them in practice?
Three steps:
  1. Extract coil geometry; slice into straight segments and compute quasi‑static B‑field.
  2. Drive with known current; simulate the sample region.
  3. Measure with a field meter; refine geometry and current to match targets. [Elektroda, Anonymous, post #21681449]
Does coil elevation (1–6 ft) matter here?
Not much for far‑field radiation at these frequencies. The setup operates in the near field, where geometry and distance dominate, and the overall pattern reduces to a weak dipole at range. [Elektroda, Anonymous, post #21681436]
