  • A simple musical Tesla coil was rebuilt from a single-transistor design so it could play tunes instead of only lighting fluorescent lamps.
  • The primary was changed to 5 turns, the secondary to about 1000 turns on a 5 cm PVC pipe, and a yellow LED plus a second transistor improved robustness.
  • The coil ran at 30 V and about 30 W using a LRS-100-36 supply reduced from 36 V.
  • An ESP8266 generated square waves to drive a 2N7000, shorting the transistor bases to ground and making the coil play simple tunes.
  • The circuit was only temporarily soldered on a universal board, and the author notes the schematic still has shortcomings.
  • A simple Tesla music coil
    I've always wanted to build a musical tesla coil, but I was overwhelmed by the complexity of the design schematics found on the internet. Some time ago I found a schematic of a single transistor based coil and decided to improve it so that it could play sound. I decided to share the project so that others could make such a simple coil.
    Here is the diagram I found:
    The effect of her work was poor, no spark, only the fluorescent lamps were getting closer to light. I increased the number of windings to 5 on the primary (I made them from a 1.5 mm? cable ;) and around 1000 on the primary. There are 25 cm of windings with 0.25 mm diameter wire on a 5 cm diameter PVC pipe. After this procedure, the spark was immediately bigger, but a new problem appeared, the transistor did not last a long time and soon it fell. I experimented with many transistors and got a good result using the BD239. The transistor burnout problem was rare, but I wanted to eliminate it completely. It was helpful to replace the semiconductor diode connected in reverse to the base of the transistor with the LED - and attention, specifically the yellow one - and the insertion of a second transistor. Due to the fact that these transistors have more power, I increased the voltage of the system to 30 V, increasing the power of the coil to about 30 W (value read from the service power supply). I suspect that the tension can be increased a little more.
    The next step was to make the coil play. I used ESP8266 (it was handy, and I had code for arduino on the disk that plays simple tunes). ESP generates a square wave with a given frequency, which controls the unipolar transistor (2N7000), short-circuiting the bases of the transistors controlling the coil to ground. In this way, we managed to get a nice and loud sound from the coil.
    Finally, I made a casing from some IKEA box that happened to be at home. As a power supply I used a 36 V impulse power supply (LRS-100-36, I had it from some electro-scrap that I got as a "gift" for parts), I reduced its voltage to 30 V with the potentiometer on it.
    I know that the scheme has some shortcomings, it was just created as much as my knowledge allowed, there is definitely something to be improved in it. It is as follows:
    I soldered everything temporarily on a universal board, there are plans to make a printed circuit board.
    Unfortunately, I didn't take photos during the creation, but I put in those with the coil ready.
    A simple Tesla music coil A simple Tesla music coil
    A simple Tesla music coil A simple Tesla music coil A simple Tesla music coil
    1st movie:
    Program code for ESP8266 (written in Arduino IDE) I attach to the topic. ESP provides a page on the local network where you can select a track to play. I add a second program that works immediately after startup (it does not connect via Wi-Fi, only plays one track in a circle).
    Regards
    PS.
    It should be noted that the Tesla transformer generates a high voltage of several kilovolts, so be especially careful when working!
    • program.zip (12.82 KB) You must be logged in to download this attachment.
    • program_bez_wifi.zip (4.1 KB) You must be logged in to download this attachment.
    patrykkurzejago
    patrykkurzejago wrote 8 posts with rating 33. Been with us since 2022 year.
  • #2 20144536
    bambus94
    Help: 245
    Rate: 717
    Have you checked the frequency of work? As it goes in hundreds of kHz or even MHz, you could try something similar to a class D amplifier and then even normal mp3 would play. Kind of like my HFVTTC link below in featured.
    You already have experience, now SSTC halfway or rich and DRSSTC.
  • Using rtl-sdr to find the coil frequency
    #3 20144563
    patrykkurzejago
    Rate: 33
    Unfortunately, I do not have an oscilloscope or even a multimeter with frequency measurement. I also do not know how to check or calculate this frequency in another way :( Does such a coil emit radio frequency at its operating frequency? Because if so, I have rtl-sdr that I could search for this frequency.
    I found that building this only spurred me to build something bigger. It's very addictive, so I'm thinking about it :D
  • Tesla coil frequency may need SDR upconverter
    #4 20144574
    bambus94
    Help: 245
    Rate: 717
    Yes, the Tesla coil is essentially a radio transmitter.
    A well-tuned one should generate radio waves with a length equal to the length of the wire on the secondary winding. A less tuned one will transmit at the frequency depending on the inductance and capacitance of the secondary winding.
    If the SDR catches you a few MHz range, then maybe you can catch it. And if not, maybe you should make an Up-Converter to SDR? I have one that raises the frequencies by 80 MHz and can pick up stations from several dozen kHz.
  • #5 20144595
    patrykkurzejago
    Rate: 33
    Then let me look for that frequency in a moment. I have an SDR with the R820T2 chip and it reaches up to 1864 MHz.
  • #6 20144607
    bambus94
    Help: 245
    Rate: 717
    Rather, you have to look at the lower range, that is, a single MHz. Even if you catch something, you cannot be 100% sure of this frequency, because it may be one of the next harmonics.
  • #7 20144646
    patrykkurzejago
    Rate: 33
    I rummaged through the manual and it turned out that my SDR ranges from 0.1 MHz to 1.7 GHz (it was enough to change the settings). The coil emits a strong wave at 1.037 MHz, if it's playing a song, I have modulation and can hear music from the radio.
  • #8 20145626
    Janusz_kk
    Help: 228
    Rate: 1481
    Not true, the resonant circuit is inductance and capacitance, not the length of the wire.
  • #9 20145631
    bambus94
    Help: 245
    Rate: 717
    Yes, but a well-calculated Tesla coil has a resonant frequency equal to that of a wire-length wavelength on the secondary winding. This is why toruses are used to vary the resonant frequency to tune this frequency to the length of the wire.
  • Too-high frequency is heating the transistors
    #10 20145799
    Janusz_kk
    Help: 228
    Rate: 1481
    bambus94 wrote:
    Yes, but a well-counted Tesla coil has a resonant frequency
    equal to inductance and inter-winding capacitance.
    that someone also wanted to look for such a relationship :) normally no one is concerned with such dependencies.
    Anyway, the author has too high a frequency and that is why the transistors heat up so much for him, more energy goes into heat than into a spark, therefore the remarks about the danger are thought over because at the currents offered by the coil it will not hurt anyone.
  • #11 20145821
    bambus94
    Help: 245
    Rate: 717
    Well, someone found it and everyone who wants to have good results applies to this dependence.
  • #12 20145912
    zulugula
    Help: 27
    Rate: 63
    Every radio amateur will tell you that the best amplifier is the antenna, and by choosing its dimensions and the length of the wire, you tune it.
    And wasn't the length of the wire 1/4 or 3/4 of the length?
  • #13 20145926
    bambus94
    Help: 245
    Rate: 717
    From what I remember it was 1 or 1/2 wavelength. I have to look for an email from a man who did something about 40 cm of arc on VTTV on GU81.
  • Primary winding adjustment reduced transistor heating
    #14 20146027
    patrykkurzejago
    Rate: 33
    Janusz_kk wrote:
    Anyway, the author's frequency is too high and that is why the transistors heat up so much for him, more energy goes into heat than into a spark, so the remarks about the danger are thought over because at the currents offered by the coil it will not hurt anyone.
    If someone has a pacemaker, a heart defect, a disturbed potassium-sodium balance, or some other heart conductivity problem, such a coil is very dangerous. At best, a healthy person can burn, but I still recommend caution. It is better to be careful than the effect of your work from the "top".
    When it comes to electronic devices at home, I was approaching the coil with a sports wristband or the phone and nothing happened, but I have Google Nest speakers at home and after activating the coil, even those in the next room go down and get louder at random moments.
    zulugula wrote:
    And was the length of the wire not 1/4 or 3/4 of the length?
    I was building a GP antenna with a 3/4 wavelength radiator and building a 1/2 wavelength half-wave dipole, so you both might be right. Both structures were built on the basis of information from the club's hams, and both worked properly.
    Janusz_kk wrote:
    Anyway, the author's frequency is too high and that's why the transistors are so hot for him.
    At the moment, by manipulating the primary winding (mainly up and down), it was possible to obtain the greatest spark and minimum heating of the transistors. The heatsink that I used at the moment is greatly exaggerated, after 10 minutes of operation, the coil is 35 degrees (at 23 degrees at home). In this design, the frequency depends on the LC circuit made of the secondary winding and the capacitance between the windings.
  • #15 20146689
    Janusz_kk
    Help: 228
    Rate: 1481
    patrykkurzejago wrote:
    If someone has a pacemaker, heart defects, a disturbed potassium-sodium balance or any other problems with the conductivity in the heart, such a coil is very dangerous
    Epidermis, read how much it is at 1 MHz.
    But the coil is not an antenna.
  • Tesla generator tuned via primary winding and torus capacitance
    #16 20147034
    rosomak19
    Rate: 402
    I would be more tempted to use the term Tesla's generator or transformer, not "coil"; Second thing, the Tesla generator is tuned with the primary winding, not the secondary one. The third thing, the torus, is the capacitor (or more precisely, one of its facings, because the other is Earth), which is part of the resonant circuit of the secondary circuit. Its capacity is calculated on this basis, then its physical dimensions are calculated. As for the primary winding, it is always a few more turns than calculated. With the alligator clip you can change the inductance of the winding in order to best match the resonant frequency of the primary circuit to the secondary one. In a classic generator with a trafa from 10 kV / 50 mA neon, after calculating the coils and capacitor, adjusting on the primary one, I achieved discharges into the air at a distance of 1 meter! With such a low power of the supply transformer, it proves the perfect alignment of the circuits. Finally, I would like to add that the secondary winding is basically a quarter-wave dipole antenna.
  • EM field and pacemaker risk at 1 MHz
    #17 20147082
    patrykkurzejago
    Rate: 33
    What about the electromagnetic field? It seems to me that the starter is shielded in some way and the risk is minimal, but I wonder if anyone knows anything more about it. I even remember in high school, before the teacher started the electrostatic machine, he asked if anyone had a pacemaker, on the other hand, clothing a sweater could be dangerous then. I know personally a situation in which an electrostatic discharge from a TV picture tube killed a woman with a cardiac arrhythmia. However, I am aware that this case was quite "exotic" and rare.
  • #18 20147265
    zulugula
    Help: 27
    Rate: 63
    As @ rosomak19 wrote, it can be considered a quarter-wave plate, but for proper resonance it needs to be tuned with a suitable capacitor, e.g. a torus. Finally, tune the resonance in the primary circuit.
    As for heart pacemakers, while the epidermal effect is in favor, such a strong electromagnetic field, especially in systems with a magneto, is not so negligible.
  • #19 20147601
    rosomak19
    Rate: 402
    I do not know about your musical Tesla, but with my classic one, the field was so strong that the fluorescent lamp in my hand shone from a long distance. I do not know about the starter, but the phone and camera survived filming the discharges. The problem here is the very significant ozone release, and it is quite significant.
  • #20 20147607
    bambus94
    Help: 245
    Rate: 717
    I would be more afraid of nitrogen oxides than ozone.
    It was one of the first industrial methods of producing nitrogen oxides and then nitric acid. An electric arc in the air, later refined by the addition of magnets, resulted in a spinning electric arc in the air. Interestingly, this technology was developed and effective by a Pole, but I do not remember the name.
  • Secondary winding length matches half-wave resonance
    #21 20147860
    patrykkurzejago
    Rate: 33
    It fires fluorescent lamps from several dozen centimeters, Google speakers are standing in the next room and they are freaking out. I approached the transformer with the smart band on purpose (I forgot about it), the phone was in my other hand and nothing happened. As for ozone, it is noticeable, but not an intense smell. About two years ago I had a neighbor who dealt with ozonation and I was in a room where the ozone concentration was at an acceptable level (measured with a meter), and the smell was very intense and left such a strange feeling in the nose. So the ozone itself here doesn't seem to be a threat.
    As for nitrogen oxides, I put a moistened litmus paper close to the arc, after a while it turned red, so it actually arises.
    25 cm of 5 cm diameter windings are wound with 0.25 mm wire. So the length of the wire used is about 157 m (the windings are tight, but the 7 m can be less) of the wire, the 1 MHz wave is 300 m long. It would turn out that the length of the secondary winding corresponds to 1/2 of the wavelength . I can be wrong of course. The secondary winding is an LC circuit and logic dictates that this is just a coincidence.
  • Debunking the skin effect safety myth
    #22 20152362
    _lazor_
    Help: 259
    Rate: 1132
    As such a topic gives a warning:
    The epidermal effect does not protect against infection:
    https://en.wikipedia.org/wiki/Tesla_coil#Skin_effect_myth
    The shock effect also does not feel above a certain frequency because our system will not react:
    http://amasci.com/tesla/teslafaq.html#two
    Such a toy does not offend too much because it does not carry a lot of energy at the exit. Please fight the myth of the anti-paralytic epidermal effect!
  • Warning that even low-energy Tesla coils can still hurt
    #23 20152403
    rosomak19
    Rate: 402
    I would argue a bit, because whether it "tickles" someone or "potelepie" depends on several factors, including individual ones. If I were the moderator, I would not write such assurances, encouraging young inexperienced amateurs of high tension to try, or to "kick" hard. Each toy can hurt you under favorable conditions.
  • Epidermal effect does not prevent injury
    #24 20152409
    Janusz_kk
    Help: 228
    Rate: 1481
    I did not write that it only reduces significantly. For sure the effect is different for 50 Hz and different for 1 MHz.
    After all, I wrote the same.
    Janusz_kk wrote:
    therefore, the remarks about the danger are imaginary, because at the currents that the coil offers, it will not hurt anyone.
    Maybe start with yourself? :)
    Look at what you answer and what the power range is.
  • Skin effect does not make Tesla coils safe
    #25 20152493
    _lazor_
    Help: 259
    Rate: 1132
    rosomak19 wrote:
    I would argue a bit, because whether it "tickles" someone or "potelepie" depends on several factors, including individual ones. If I were the moderator, I would not write such assurances, encouraging young inexperienced amateurs of high tension to try or "kick". Because every toy can hurt you under favorable conditions.
    The myth of the epidermal effect protecting a magical beginner who doesn't even have an oscilloscope is even more dangerous. Especially since they somehow assume that there are single MHz where the resonant frequency is often several hundred kHz.
    Maybe it will also specify that I did not mean that every Tesla transformer has low energy at the output and is therefore safe, I mean that it is not the epidermal effect that protects against electric shock. It is impossible to compare the phenomenon of the epidermal effect for the environment where there are two spaces with different parameters (electric conduit and air) to the environment with a very large amount of space with different parameters. And the fact that they called it the epidermal effect, it never meant that the current was flowing over the human skin ...
  • Measured 161.6 kHz resonance and lamp strike risk
    #26 20152548
    rosomak19
    Rate: 402
    Let me say on my example, my classic Tesla had a resonant frequency of 161.6 kHz. Fortunately, while playing with the fluorescent lamp, I reduced the power of the power supply, despite this I inadvertently brought it too close to the torus and the discharge went to the fluorescent lamp, thus to me. Let me put it this way, I felt like having fun in a moment. I don't know what would happen if it was at full power.
  • #27 20152555
    Janusz_kk
    Help: 228
    Rate: 1481
    rosomak19 wrote:
    Let me put it this way, my desire for a moment changed to such games,
    What were you counting on? that he will only 'stroke' you :)
    Electrocution always has some effects, but the fact that they do not infect internal organs is much less dangerous than 50 Hz or DC, but that does not mean that they are pleasant.
  • #28 20152878
    rosomak19
    Rate: 402
    I wasn't counting on anything except the effect of the fluorescent lamp lighting up under the influence of a strong electromagnetic field, but I got too close.
  • #29 20152972
    _lazor_
    Help: 259
    Rate: 1132
    rosomak19 wrote:
    I was not counting on anything except the effect of the fluorescent lamp lighting up under the influence of a strong electromagnetic field, but I got too close
    At 161 kHz, we are talking about an electromagnetic field, but a close one (wavelength about 1800 m), and due to the fact that the current flowed negligibly, it was under the influence of a strong electric field.
  • 350 kHz resonance and grounding concerns
    #30 20162812
    KJ
    Help: 68
    Rate: 945
    The resonance with these winding parameters and without any toroid should be around 350kHz. The epidermal effect vs tesla - yes, everyone writes about it everywhere is only 1 small ... okay 2 quite big problems with this phenomenon in the context of current flow through tissues. First of all, the human body is not a homogeneous conductor, secondly, it is largely an ionic conductor, which roughly means that the epidermal effect is not manifested here by the current flow over the skin as it is usually described. Could it be dangerous? It depends on the scale - such a tessel will not harm anyone healthy in an accidental contact with the discharge, but this size DRSSTC where the instantaneous currents in the discharge calmly reach several A? I would think twice. The classic Tesla coil in the context of the epidermal effect has one more problem - in the discharge current there is almost always a 50 / 100Hz component and in the event of a breakdown between the primary and secondary its value will reach dangerous levels. Freaking electronic devices further away from the Tesla (e.g. in another room) usually indicates that it is not properly grounded. The problem is the greater the higher the resonant frequency, because the resistance, or more precisely, the impedance of a typical earthing circuit in a classic electrical installation for high frequencies, usually differs significantly from what results from the measurements - after all, electrical installations are adapted and standardized for 50Hz. As for the dependence of the wavelength equal to the length of the wire - I hear first, but it could explain a lot - out of curiosity, I will check what it looks like in my designs.
The discussion revolves around building a simple musical Tesla coil, with the original poster sharing their experience of modifying a single transistor-based design to produce sound. Initial attempts resulted in poor performance, prompting adjustments to the winding configuration, which improved spark generation but led to transistor failures. Participants suggested checking the operating frequency, as Tesla coils function as radio transmitters, and discussed the importance of tuning the resonant frequency through inductance and capacitance. The use of an SDR (Software Defined Radio) was proposed to detect the coil's frequency, which was found to be around 1.037 MHz during testing. Safety concerns regarding electromagnetic fields and the potential dangers of high-voltage discharges were also highlighted, with warnings about the risks to individuals with heart conditions. The conversation included technical insights on resonant circuits, the epidermal effect, and the generation of ozone and nitrogen oxides during operation.
TL;DR: A 30 W, 1.037 MHz musical Tesla coil proves that “Tesla coil is essentially a radio transmitter” [Elektroda, bambus94, post #20144574] while remaining buildable with two BD239 transistors [Elektroda, patrykkurzejago, post #20144206] Safe handling and proper tuning are critical. Why it matters: Even small coils can burn skin, jam Wi-Fi and broadcast unintended RF.
• Resonant frequency: 1.037 MHz detected with RTL-SDR [Elektroda, patrykkurzejago, post #20144646] • Supply: 30 V DC from trimmed 36 V SMPS [Elektroda, patrykkurzejago, post #20144206] • Output power: ≈30 W at 1 A [Elektroda, patrykkurzejago, post #20144206] • Windings: Primary 5 turns / 1.5 mm; Secondary ≈1000 turns / 0.25 mm [Elektroda, patrykkurzejago, post #20144206] • SDR coverage 0.1 MHz–1.7 GHz with R820T2 tuner [Elektroda, patrykkurzejago, post #20144595]
1. What schematic was the starting point for this build?
The author began with a single-transistor SSTC diagram found online, then redrew it to use two BD239 NPN transistors, an LED across the bases and an ESP8266 audio gate [Elektroda, patrykkurzejago, post #20144206]
2. Which modifications increased spark length?
Increasing primary turns from 3 → 5, raising supply to 30 V and adding ~1000 secondary turns boosted spark visibility and lamp excitation [Elektroda, patrykkurzejago, post #20144206]
4. How does the coil play music?
An ESP8266 outputs a square-wave melody; a 2N7000 FET grounds the transistor bases rhythmically, amplitude-modulating the RF and producing audible plasma tones [Elektroda, patrykkurzejago, post #20144206]
5. How can I measure resonance without an oscilloscope?
Use an RTL-SDR dongle: the coil radiates; tune from 0.5–5 MHz until you see a strong peak (1.037 MHz in this project) [Elektroda, patrykkurzejago, post #20144646] Alternatively, compute f ≈ 1 / (2π√LC) with online calculators when L and C are known.
7. What effects on nearby electronics were observed?
Google Nest speakers in the next room randomly changed volume; fluorescent lamps lit from ≥30 cm; smart-band and phone survived close passes [Elektroda, patrykkurzejago, post #20146027]
8. Can I raise the supply voltage for bigger arcs?
Yes, but transistor heating rises with frequency. Users report safe operation up to 30 V; beyond that, core losses and transistor SOA limit apply [Elektroda, patrykkurzejago, post #20144206]
9. How do I tune a Tesla coil efficiently?
  1. Wind secondary first and calculate its self-resonance. 2. Start with extra primary turns. 3. Slide an alligator clip to vary inductance until spark length maximises and transistor heat minimises [Elektroda, rosomak19, post #20147034]
10. What is the wavelength-equals-wire-length debate?
Some hobbyists aim for secondary wire length ≈ ½ λ; others focus solely on LC resonance. Experts note performance depends on L and C, not wire length alone [Elektroda, Janusz_kk, post #20145799]
11. Which gases form around the arc?
Ozone and nitrogen oxides form; litmus paper turned red near the arc, confirming NOx presence [Elektroda, patrykkurzejago, post #20147860] Prolonged exposure above 0.1 ppm ozone irritates lungs [EPA, 2023].
12. What primary and secondary wires work best?
Use 1–2 mm² copper for the primary to handle currents; 0.2–0.3 mm enamelled magnet wire suits a 25 cm secondary, giving ≈1000 turns [Elektroda, patrykkurzejago, post #20144206]
13. How can I reduce transistor heating?
Lower resonance by adding a toroid or increasing secondary height; reduced frequency cuts switching losses. Ensure a heat-sink keeps case <70 °C [Elektroda, Janusz_kk, post #20145799]
14. What myths surround the skin effect?
High-frequency current still penetrates tissues because the body is ionic and inhomogeneous; skin effect does not guarantee safety, especially in DRSSTC class where peak discharge current can reach amps [Elektroda, KJ, post #20162812]
15. 3-step: Measure frequency with RTL-SDR
  1. Power the coil a short distance from the antenna.
  2. Open SDR software, set range 0.5–5 MHz, gain low.
  3. Identify the strongest peak (e.g., 1.037 MHz) and note harmonics. [Elektroda, patrykkurzejago, post #20144646]
