Output only 230 mV instead of 5V in non-inverting summing amplifier circuit—why?
294 7
  • #1 21682038
    Anjali Agarwal
  • #2 21682039
    Aubrey Kagan
  • Non-inverting input needs a ground path
    #3 21682040
    David Ashton
  • #4 21682041
    David Ashton
  • #5 21682042
    PeterTraneus Anderson
  • #6 21682043
    Richard Gabric
  • #7 21682044
    Anjali Agarwal
  • Simulation gives 5.225 V for non-inverting summer
    #8 21682045
    David Ashton
A non-inverting summing amplifier circuit designed to output 5 V was instead producing only 230 mV. Investigation revealed that the non-inverting input lacked a proper path to ground, which affected the output voltage. Simulation in Multisim showed that adding a resistor from the non-inverting input to ground improved the output voltage but altered the gain. Removing a feedback resistor (R4) restored the expected 5 V output in simulation. Theoretical analysis confirmed the circuit should yield 5 V output, but practical issues such as offset voltage and wiring faults can cause discrepancies. The complexity of the non-inverting summing amplifier's transfer function was noted, with a recommendation to use the inverting summing amplifier configuration for simplicity. Ultimately, correct wiring resolved the issue, aligning real-world results with theoretical expectations.
