UA741CP Op-Amp Output Stuck at 0.69V in Non-Inverting Amplifier Circuit with Gain 11
1011 18
Why does my UA741CP non-inverting amplifier with a gain of 11 only output about 0.69 V instead of about 11 V from a 1 V input?
Your circuit was not seeing a steady 1 V DC input; the Arduino `analogWrite` output is PWM, so a multimeter can show only a low average voltage like 0.69 V even while the op-amp is amplifying the waveform correctly [#21676657][#21676659] Add the recommended supply bypassing: 10 µF in parallel with 0.1 µF on the LM317 output and a 0.1 µF capacitor right at the 741 supply pins [#21676657] To verify the 741 itself, disconnect the Arduino and apply a known DC input from a small divider off a 1.5 V battery; with about 0.7–0.8 V on pin 3, pin 2 should match pin 3 and the output should be about 11 times that voltage [#21676658] If you want a true DC signal from the Arduino, filter the PWM with an RC low-pass first, or use a scope to confirm the waveform [#21676657][#21676659]
  • UA741CP likely miswired or missing proper supply rails
    #1 21676641
    Mohamed Rushdy
  • #2 21676642
    Dean Franks
  • #3 21676643
    Mohamed Rushdy
  • #4 21676644
    Dean Franks
  • #5 21676645
    richard gabric
  • #6 21676646
    Mohamed Rushdy
  • Check 741 supply rails and pin voltages
    #7 21676647
    Dean Franks
  • Offset null pin measuring -11.25 V on UA741CP
    #8 21676648
    Mohamed Rushdy
  • #9 21676649
    richard gabric
  • Virtual ground buffer enabled ±15 V supply
    #10 21676650
    Mohamed Rushdy
  • Check whether the supply is truly floating
    #11 21676651
    richard gabric
  • #12 21676652
    Mohamed Rushdy
  • Request DVM measurements and a grounded voltage diagram
    #13 21676653
    richard gabric
  • #14 21676654
    Mohamed Rushdy
  • Suggesting oscillation, ripple, or damaged 741
    #15 21676655
    richard gabric
  • LM317 supply and Arduino PWM source details
    #16 21676656
    Mohamed Rushdy
  • Need output caps, 741 bypassing, and PWM filtering
    #17 21676657
    Dean Franks
  • Test 741 DC gain with divider input
    #18 21676658
    richard gabric
  • PWM output fooled the voltmeter reading
    #19 21676659
    Mohamed Rushdy
A UA741CP operational amplifier was used in a non-inverting amplifier configuration with a gain of 11 to amplify a 1 V DC input signal. Despite successful simulation results, the real circuit output was stuck at approximately 0.69 V. Initial troubleshooting focused on power supply issues, revealing the necessity of a dual ±15 V supply rather than a single 15 V supply, as the 741 requires at least ±10 V rails for proper operation. After correcting the power supply to provide symmetrical ±15 V rails using a virtual ground created by a second op-amp, the circuit began functioning but with a lower than expected gain (~3.4 instead of 11). Further investigation identified that the input signal from an Arduino PWM pin was not a true DC voltage but a pulse-width modulated signal, causing the output to oscillate and the multimeter to read a reduced DC level. Recommendations included adding RC filtering to smooth the PWM signal, using bypass capacitors on the op-amp power pins, and decoupling capacitors on the LM317 voltage regulator output. The final resolution confirmed the op-amp was working correctly, and the issue was due to the nature of the Arduino PWM input rather than the amplifier circuit itself.
TL;DR: If a UA741CP amplifier shows ~0.69 V or low gain, add 10 µF + 0.1 µF decoupling and remember the Arduino PWM is “not actually an analog signal.” Fix the input with an RC filter and verify supplies. [Elektroda, Dean Franks, post #21676657] Why it matters: These quick checks solve most “stuck output” and wrong-gain complaints without replacing parts, saving time and boards.
Quick-Facts
Why is my UA741CP output stuck around 0.69 V?
That symptom matches a failed 741 that clamps near one diode drop. Try a unity‑gain buffer test and swap the chip. Also check supply polarity and bypass caps. A damaged device or mis‑bias can pin the output near ~0.7 V. [Elektroda, Dean Franks, post #21676644]
Do I need a dual supply for the 741, or will +15 V single supply work?
Use a true dual rail. Guidance in the thread was ±10 V minimum between V+ and V− for proper linear range. A single +15 V rail risks input/output hitting limits. Wire ± supplies correctly before further debugging. [Elektroda, Dean Franks, post #21676647]
My simulator shows 11× gain, but hardware gives ~3.4 V. What’s wrong?
Simulation often ignores rail limits and PWM inputs. The Arduino output is PWM, so a DMM reads only the average. Add an RC filter, decouple the op‑amp, and confirm proper ± rails; then re‑measure with a scope. [Elektroda, richard gabric, post #21676653]
How do I make Arduino PWM into a steady 1.00 V DC for the 741?
Add a simple RC low‑pass at the PWM pin before the op‑amp. The mentor note: “The output of an arduino using analogWrite is not actually an analog signal.” Choose R and C for your PWM frequency and ripple target. [Elektroda, Dean Franks, post #21676657]
What decoupling should I use for stability with LM317 and UA741?
Place 0.1 µF ceramic directly across the 741’s supply pins. On the LM317 output, use 10 µF in parallel with 0.1 µF. These parts tame ripple and prevent oscillations that corrupt readings. [Elektroda, Dean Franks, post #21676657]
How can I test the op‑amp’s DC gain without Arduino noise?
Drive pin 3 from a 1.5 V cell through a divider (two 1–10 kΩ resistors). Expect ~0.7–0.8 V at pin 3 and ~11× that at the output if feedback is set to 11. Inputs should match in linear operation. [Elektroda, richard gabric, post #21676658]
What is a non‑inverting amplifier, in simple terms?
It feeds the input to the + pin and uses negative feedback so the − pin follows the + pin. With feedback set for gain 11, 1.00 V in targets ~11 V out, assuming rails and headroom are correct. [Elektroda, richard gabric, post #21676655]
Could my power supply wiring be the real problem?
Yes. Misusing a single supply or a non‑floating supply breaks the reference. Verify a floating source or proper dual rails. If you create a virtual ground, understand its current limits and how loads return. [Elektroda, richard gabric, post #21676651]
My DMM shows the wrong voltage—how do I verify the signal shape?
A DMM averages PWM and hides ripple. Build a low‑cost Arduino‑based scope or use any scope to see the waveform. Capture to an array, then dump over serial for clarity. [Elektroda, Dean Franks, post #21676657]
What quick 3‑step process will isolate the fault?
  1. Rewire as a unity‑gain buffer and record all 741 pin voltages to ground.
  2. Add 0.1 µF at the 741 and 10 µF||0.1 µF at LM317; confirm ± rails.
  3. RC‑filter PWM or use a battery divider, then check output gain. [Elektroda, Dean Franks, post #21676647]
What is Arduino PWM, exactly?
Arduino analogWrite outputs a fixed‑amplitude square wave with variable duty cycle. The average equals your set value, but it remains PWM until you filter it. Quote: “not actually an analog signal.” [Elektroda, Dean Franks, post #21676657]
Can the 741 drive heavy loads at 11× gain?
No. The 741’s output current is limited and your virtual ground has constraints. Plan for light loads or buffer the output if needed. Overloading skews gain and can cause clipping or oscillation. [Elektroda, richard gabric, post #21676658]
Why did 32 V “fix” powering but still give wrong readings?
Raising supply voltage enabled proper bias, but the input remained PWM and the meter read only the DC component. Once filtered and scoped, the amplifier showed correct gain behavior. [Elektroda, Mohamed Rushdy, post #21676659]
How do I confirm pin numbering and avoid wiring mistakes?
Sketch the DIP with pin numbers before wiring. After assembly, measure each pin to ground and annotate the drawing. Replace the IC if temperatures rise or readings look abnormal. [Elektroda, Dean Franks, post #21676647]
What is a virtual ground and when is it risky?
A virtual ground is a generated mid‑rail reference for single‑supply systems. It must be truly floating and has current limits. If one side of your supply is earth‑referenced, the virtual ground can fail. [Elektroda, richard gabric, post #21676651]
