Setting Up Micromite on Mac OS X for Make it with Micromite Practical Electronics
234 6
  • Clarifying Micromite setup on Mac OS X
    #1 21682439
    Michelle OBrien
  • Mac setup likely requires running Windows in Parallels
    #2 21682440
    Alan Winstanley
  • Request for Mac Terminal and Screen setup instructions
    #3 21682441
    Michelle OBrien
  • Mac terminal setup guide for serial connections
    #4 21682442
    Elizabeth Simon
  • Using Terminal on macOS for Micromite setup
    #5 21682443
    PeterTraneus Anderson
  • #6 21682444
    Alan Winstanley
  • #7 21682445
    Michelle OBrien
The discussion addresses setting up the Micromite microcontroller on Mac OS X, as the original "Make it with Micromite" series primarily provides instructions for Windows PCs. Mac users are advised that the setup process is more complex due to the proprietary nature of Mac hardware and software compared to the more open Windows and Linux environments. A suggested workaround is running Windows on a Mac via virtualization software like Parallels Desktop, though compatibility with USB and terminal applications is uncertain. Mac OS X includes built-in Terminal and Screen applications that can serve as serial terminals to communicate with the Micromite, emulating traditional command-line interfaces used for microcontroller interaction. Guidance on locating and using Terminal (found under Finder > Go > Utilities > Terminal) and understanding its Unix-based shell environment is provided. Additional resources include online tutorials for setting up serial terminals on Mac OS X, originally intended for devices like the Intel Edison but applicable in principle to the Micromite. The August 2019 issue of Practical Electronics covers Micromite setup on Mac OS X 10.7, though the author acknowledges limited Mac expertise and invites input from experienced Mac users. Overall, Mac users require familiarity with command-line tools and serial communication software to interface with the Micromite, with no straightforward plug-and-play solution currently available.
