I am trying to build an equalizer on C, using fft (fast Fourier transformation), since now i am able to apply the fft correctly on the vector (audio samples) normalize it and then apply the inverse fft. since here all OK , but when i try to modify the result of the fft(to increase the gain of one or various frequency bands) i get just noise (even if i just slightly modify it).My problem is the next: im trying to build an equalizer on C, using fft (fast fourier transformation), since now im able to apply the fft correctly on the vector (audio samples) normalize it and then apply the inverse fft. since here all ok , but when i try to modify the result of the fft(to increase the gain of one or various frequency bands) i get just noise (even if i just slightly modify it). How can i modify this bins (real+imaginary) components, that mi fft is giving:(0,real, imaginary, real, imaginary...) to equalize properly?
James martin
James martin
