Does 5V Battery Voltage Travel Through Wires or Just Appear Across Them?
402 7
  • Voltage appears across wires, not travels through them
    #1 21682626
    Ryan Mco
  • #2 21682627
    Ryan Mco
  • #3 21682628
    David Ashton
  • Advise learning basics before detailed circuit questions
    #4 21682629
    Elizabeth Simon
  • Current flows through wire despite low resistance
    #5 21682630
    Max Maxfield
  • How voltage is distributed along a wire
    #6 21682631
    Ryan Mco
  • Voltage as pressure, current as flow analogy
    #7 21682632
    Elizabeth Simon
  • #8 21682633
    Ryan Mco
The discussion centers on understanding how a 5V battery voltage appears across wires connected to its terminals and whether voltage "travels" through the wires. The question arises from confusion about how wires can hold or exhibit the same voltage as the battery without apparent current flow. Clarifications emphasize that wires do possess small resistance, though often negligible. Voltage is described as an electric potential difference, analogous to water height in a pipe, which does not "travel" but exists due to the connection to the voltage source. Current, representing charge flow, is what physically moves through the wire when a circuit is closed. The wire's electrons respond collectively to the applied voltage, creating a potential difference along the conductor. The analogy of water in a pipe illustrates that voltage corresponds to potential level, while current corresponds to flow rate. The key takeaway is that voltage is a property established by the battery and the circuit configuration, not a substance that traverses the wire, whereas current is the actual movement of charge carriers through the conductor.
