I have searched for this simple answer and I can't seem to come up with a good clear answer. In the supplied circuit picture, how can this circuit be hardened for an inductive load such as a ceiling fan? Can I put a TVS diode or MOV across the 'Load Hot' and 'Neutral' terminals? I have seen both mentioned, but then both are also said to be wrong. I have seen that TVS diodes is the way to go but might not be UL approved. Doesn't have to be, but wanted to build on best practice. MOV's appear to be the right answer, but have seen people say they are too slow for this application. I have also seen RC snubber designs but I know this can cause other issues with small loads. Not sure. Please help!
Matthew Wood
Matthew Wood
