How to Select Control Panel Components for Riello Press1G Burners & Single Thermocouple
258 12
How can I design a control panel for an incinerator that uses one thermocouple to switch three burners between high burn and low burn?
The simplest approach is to use a thermocouple signal conditioner or limit controller set to 800°C to drive relays/contactors for the burner stages, with a 24VDC control supply, an emergency stop, and a timer or shutdown interlock; a small PLC is a good alternative if you want more safeguards [#21682779][#21682780] Aubrey suggested one relay for the lower burner and another for the two upper burners, with the upper-burner relay released when the temperature rises above 800°C [#21682779] David noted that a small PLC would be ideal because there are only a few inputs and outputs, but discrete relays/timers require careful wiring and extra safety shutdown logic [#21682780] Because this is a fuel-burner installation, certified components and the required inspection matter, and the Riello burner package already includes a microprocessor-controlled safety control box plus wiring diagrams in the manual [#21682781][#21682783]
  • Single thermocouple control strategy for staged burners
    #1 21682777
    Nacanieli Tabua
  • Suggesting an Arduino-based burner controller
    #2 21682778
    David Ashton
  • Recommend thermocouple transmitter with limit relay control
    #3 21682779
    Aubrey Kagan
  • PLC recommended with added fire-safety safeguards
    #4 21682780
    David Ashton
  • Certification and safety concerns for gas burner controls
    #5 21682781
    Aubrey Kagan
  • #6 21682782
    Nacanieli Tabua
  • #7 21682783
    David Ashton
  • Thermocouple proposed as thermostat replacement for burner control
    #8 21682784
    Nacanieli Tabua
  • #9 21682785
    Aubrey Kagan
  • Need igniter, fan, and certification details
    #10 21682786
    Steven George
  • Use certified igniters and add fan purge timing
    #11 21682787
    Steven George
  • #12 21682788
    vimprome storunts
  • #13 21682789
    vimprome storunts
The discussion focuses on designing a control panel for a biomedical waste incinerator equipped with three Riello Press1G oil burners (model 3474520) and a single thermocouple sensor. The control logic requires all burners to operate initially, with the two top burners shutting off once the temperature exceeds 800°C, leaving the bottom burner running for low burn mode; all burners operate during high burn. Key considerations include selecting appropriate control components capable of handling 3-phase 400V power for the burners and integrating ignition transformers (230V, 8kV @ 1.8A, 30mA). Safety is paramount due to fire and explosion risks associated with oil burners, necessitating emergency stop functions, interlocks to prevent chamber access until cooled, and compliance with regulatory standards such as UL and CSA. A programmable logic controller (PLC) is recommended for reliable control and safety interlocks, though microcontrollers like Arduino could be used with sufficient expertise. Certified components are preferred to simplify compliance and inspection. The thermocouple type and signal conditioning (e.g., 4-20mA or 0-10V output) must be identified for proper integration. Power supply considerations include whether to use single-phase feed or bus bars. Visual indicators and timers for automatic shutdown are advised to enhance operational safety and monitoring. The project is an existing installation maintained by a service department, with a trainee engineer seeking a straightforward yet safe control solution.
TL;DR: For a 3‑burner incinerator with an 800 °C cutoff, the simplest safe control uses a "power supply, signal conditioner, and a relay." [Elektroda, Anonymous, post #21682779]
Why it matters: This FAQ helps trainee and working engineers choose control‑panel components for Riello Press1G burners using a single thermocouple, balancing simplicity and safety.
What’s the simplest control‑panel approach with one thermocouple?
Use a thermocouple transmitter with an adjustable limit. Drive one relay for the two top burners and keep the bottom burner powered. Add a 24 VDC power supply for logic and coils. This gives temperature‑based staging without programming. "Power supply, signal conditioner, and a relay" covers the core. [Elektroda, Anonymous, post #21682779]
How should the burners switch around 800 °C?
Start in high burn with all three burners on. When the thermocouple reads above 800 °C, switch off the two top burners. Keep the bottom burner running for low burn until the cycle completes or the chamber cools to your setpoint. [Elektroda, Anonymous, post #21682778]
Can I control this with a PLC or Arduino?
Yes. A small PLC suits the few inputs and 2–3 outputs and adds timers and interlocks. If you won’t learn PLC programming, contract it out. A discrete transmitter‑relay panel also works if you prefer no code. [Elektroda, Anonymous, post #21682780]
What safety and certification should I plan for?
Treat fuel systems as life‑safety. Expect UL/CSA inspections and design using already certified ignition and safety components. This reduces redesign and speeds approval. Add emergency‑stop, door interlocks, and cool‑down logic to mitigate fire and explosion hazards. [Elektroda, Anonymous, post #21682781]
Are these Riello Press1G units gas or oil burners?
They are oil burners. One contributor linked the datasheet and installation manual, noting built‑in microprocessor safety and simple shutdown contacts in the diagrams. Plan your panel to interface with those safety contacts. [Elektroda, Anonymous, post #21682783]
What electrical specs from the site should I consider first?
Expect 3‑phase 400 V supply to the burner and a 230 V ignition transformer producing about 8 kV (approx. 30 mA secondary). Size control components and isolation accordingly. Keep control power separate from motor circuits to reduce noise. [Elektroda, Anonymous, post #21682784]
How should I power the control electronics?
Use a dedicated 24 VDC supply for the transmitter, relays, and indicators. Avoid tapping from high‑noise motor lines. This matches the suggested no‑code architecture and keeps logic stable during burner starts. [Elektroda, Anonymous, post #21682779]
What indicators and interlocks are worth adding?
Add burner‑on status lamps, over‑temperature alarm, a cycle timer, and a chamber‑lockout until cool. Include an emergency‑stop and verify failsafe behavior on power loss. These additions mitigate unattended operation risks. [Elektroda, Anonymous, post #21682780]
What is a thermocouple transmitter (signal conditioner)?
It converts a thermocouple’s millivolts into a standard signal and can include a limit relay. Here, set the limit to 800 °C to drop out the top‑burners’ relay automatically when temperature is exceeded. [Elektroda, Anonymous, post #21682779]
What is a PLC?
A Programmable Logic Controller is an industrial computer for reliable I/O, sequencing, and safety interlocks. In this project, a small PLC can read one thermocouple input (with conditioning) and drive 2–3 outputs with timers and interlocks. [Elektroda, Anonymous, post #21682780]
What start‑up and shutdown fan logic should I consider?
Purge with circulation fans for several minutes before ignition and continue fans for several minutes after burner shutdown. This reduces explosion and fire risk. Edge case: skipping purge can allow unburned fuel to ignite violently. [Elektroda, Anonymous, post #21682781]
How do I wire a simple two‑stage control without programming?
  1. Feed a 24 VDC supply to the thermocouple transmitter and relays.
  2. Route the top‑burners’ coil power through the transmitter’s 800 °C limit contact.
  3. Wire the bottom burner coil to stay energized during the cycle for low burn. "Simple enough?" [Elektroda, Anonymous, post #21682779]
Can I run the system with only one thermocouple?
Yes. The thread’s solution assumes a single thermocouple feeding a transmitter with a limit relay. This supports automatic switchover at 800 °C and keeps hardware minimal while remaining serviceable. [Elektroda, Anonymous, post #21682779]
What site details affect my final design choices?
Confirm it’s an existing installation, maintained by a service department, and that the old thermostat failed. These constraints favor simple, maintainable hardware and leveraging Press1G’s built‑in safety interfaces. [Elektroda, Anonymous, post #21682784]
Any expert advice in one line to remember?
"Natural gas and Propane are DANGEROUS," and oil systems demand similar respect and certified parts. Build safety into every step. [Elektroda, Anonymous, post #21682781]
