How to block an AC current and only get the DC componant of a signal
555 9
How can I measure only the DC component of the current through a resistor when an AC current is also present?
Measure the combined current as a voltage across R3 with an op-amp or similar, then use a low-pass filter to remove the AC component and leave the DC part [#21683367] If the measurement point is at a high voltage, use an op-amp that can withstand it or add a resistor divider first [#21683367] A simpler passive option is an inductor, which behaves like a short at DC and presents high impedance to AC because XL = 2πfL [#21683372] A direct DC-amps multimeter was also suggested as a practical alternative [#21683367]
  • #1 21683364
    Wissal Han
  • #2 21683365
    Elizabeth Simon
  • #3 21683366
    Wissal Han
  • Measure combined current then low-pass filter AC
    #4 21683367
    Elizabeth Simon
  • #5 21683368
    Wissal Han
  • Need open-circuit detection for current source cable
    #6 21683369
    Wissal Han
  • #7 21683370
    Elizabeth Simon
  • #8 21683371
    Wissal Han
  • #9 21683372
    Faisal Maache
  • #10 21683373
    dazzy12 kafe
The discussion addresses the challenge of isolating the DC component of a current signal in a circuit where a 100A AC current source is connected in parallel with a 12V DC voltage source and a resistance. The goal is to measure only the DC part of the current crossing the resistance while blocking the AC component. Suggested solutions include using an operational amplifier to measure the voltage drop across the resistance combined with a low-pass filter to remove AC harmonics. Alternatively, a DC ammeter can be inserted in the circuit for direct DC current measurement. To detect cable disconnection in the load path, it is proposed to monitor the voltage across a parallel resistor; a significant increase in voltage indicates an open circuit. Additionally, using an inductor in series can block AC current due to its high impedance at AC frequencies while allowing DC current to pass, exploiting the frequency-dependent reactance XL = j2πfL. The circuit model includes components representing cable resistance and an audio power amplifier for simulation purposes.
