How does a capacitor block only DC and allow AC to pass through in a superimposed signal?
417 7
  • Clarifying AC plus DC waveform and capacitor behavior
    #1 21684430
    vikrant singh
  • #2 21684431
    dorcas melda
  • #3 21684432
    kanwajs33 kanwajs33
  • #4 21684433
    Elizabeth Simon
  • Capacitor explanation using charge and phase shift
    #5 21684434
    vikrant singh
  • #6 21684435
    Elizabeth Simon
  • Capacitor impedance creates high-pass and low-pass filtering
    #7 21684436
    John David Heinzmann
  • #8 21684437
    PeterTraneus Anderson
A mixed signal combining AC and DC appears as an AC waveform shifted vertically by the DC offset, meaning its centerline is displaced from zero voltage. The capacitor blocks DC by charging to the DC voltage level, effectively removing the constant offset from the output. It "separates" DC and AC components due to its frequency-dependent impedance: at zero frequency (DC), the capacitor's impedance is very high, preventing DC current flow, while at higher frequencies (AC), the impedance is low, allowing AC signals to pass. The AC component causes continuous charging and discharging cycles in the capacitor, resulting in current flow with a phase shift relative to voltage. This behavior can be understood through Fourier analysis, where the mixed signal is viewed as a sum of different frequency components. The current through the capacitor's dielectric is described as Maxwell's displacement current. Overall, the capacitor acts as a frequency-selective element, blocking steady-state DC and passing time-varying AC signals.
