How to Use LM3914 Bargraph for 12V/24V/48V Battery SOC and SSR Control for Solar
282 6
  • LM3914 accuracy and temperature drift for battery SOC
    #1 21683381
    Edward Chase
  • #2 21683382
    Maurizio Di Paolo Emilio
  • Need higher-precision resistors for divider stability
    #3 21683383
    Elizabeth Simon
  • Use prebuilt voltmeter and voltage switch modules
    #4 21683384
    Julian Edgar
  • 7812 regulator can power 99V relay module
    #5 21683385
    Edward Chase
  • #6 21683386
    Joe Semos
  • 7812-regulated voltage monitor module suggested
    #7 21683387
    Anthony Kristina
The discussion centers on using the LM3914 bargraph IC to monitor state of charge (SOC) and voltage levels of 12V, 24V, and 48V solar-charged batteries, with the goal of controlling a solid-state relay (SSR) to activate an immersion heater only when the battery SOC exceeds approximately 90%. The original poster sought a multi-voltage bargraph display capable of auto-adjusting thresholds for different battery voltages but found commercial units to be potted and inaccessible for modification. Instead, a DIY approach using an LM3914 PCB was pursued. Key technical considerations include precise voltage measurement using resistor dividers with low temperature coefficient resistors to maintain accuracy over temperature variations, and the use of voltage detection relay modules as alternatives for switching loads based on battery voltage thresholds. Suggested solutions include employing multiple LED voltmeters combined with voltage switch modules or dedicated voltage detection charging/discharging relay boards capable of operating up to 80-99V with adjustable hysteresis and timer functions. Examples of such modules were referenced from eBay listings, including DC voltage detection relay switch control boards and voltage monitoring relay switch controllers. The importance of temperature compensation in resistor selection and the potential use of resistor pairs with differing temperature coefficients to track lead-acid battery SOC shifts were also discussed. Additionally, a recommendation was made to consider integrated battery monitoring ICs like the BQ79606A-Q1 with available development kits for more advanced battery management.
