Modifying BC547 Battery Tester Circuit for 6V Lead Acid With 3 LED State Indicators
270 7
  • Request to adapt BC547 tester for 6 V lead acid LEDs
    #1 21659081
    John Builder
  • #3 21659083
    Cody Miller
  • #4 21659084
    Cody Miller
  • Two-LED battery tester using TL431 thresholds
    #5 21659085
    Olin Lathrop
  • Suggesting always-on low-current LEDs for battery status
    #6 21659086
    John Builder
  • #7 21659087
    John Builder
  • #8 21659088
    John Builder
The discussion centers on modifying a BC547 transistor-based battery tester circuit to include three low-power LEDs indicating the charge state of a 6V, 4.2Ah lead acid battery used in an RC bait boat. The desired LED indicators are red for very low battery, amber for low, and green for high charge, with LEDs always on for visibility at a distance. Suggestions include simplifying the design by using two LEDs with voltage thresholds or employing voltage dividers and transistor base-emitter voltage drops as references. For improved precision and temperature stability, a TL431 voltage reference is recommended. The boat uses MFA Como Drills Torpedo 500 DC motors rated 4.5–15V. Low consumption LEDs from Maplin are preferred for the indicators. The boat is used to carry bait up to 500 yards beyond casting range.
