30W Audio Amp Pre-Amp & Power Supply Circuit for Stereo Setup + Simple LED Battery Tester
396 8
  • #1 21669850
    Johan De Beer
  • No preamp needed for 1 V RMS audio input
    #2 21669851
    DAVID CUTHBERT
  • Clarifying stereo preamp wiring and LED battery tester range
    #3 21669852
    Johan De Beer
  • Mono amp with resistive stereo mixing and dual volume controls
    #4 21669853
    DAVID CUTHBERT
  • Needs treble, bass, and volume controls
    #5 21669854
    Johan De Beer
  • #6 21669855
    DAVID CUTHBERT
  • #7 21669856
    Johan De Beer
  • #8 21669857
    DAVID CUTHBERT
  • #9 21669858
    Jibby Benjamen
The discussion addresses building a 30W audio amplifier with pre-amplifier and power supply circuits for a stereo setup, alongside a simple LED battery tester for AA, AAA, and 9V alkaline batteries. For the audio amplifier, a standard 1 V RMS input signal from modern sources typically negates the need for a preamp; however, to achieve treble, bass, and volume control, an op-amp based preamp is recommended. Using two mono amplifiers is advised for stereo output, as commonly done in high-end systems. A resistive network with two volume controls can combine two audio sources into one amplifier, though this yields mono output. Tone controls require a dedicated preamp stage, as passive input circuits lack bass and treble adjustment.
Regarding the LED battery tester, the LM3914 LED bar graph driver IC is suitable for indicating battery voltage levels. The IC operates from a 3V or higher supply, commonly powered by a 9V battery, and can be configured for different voltage scales by adjusting resistor values (e.g., R1=6.8k and R2=1.3k for 1.5V full scale; R1=1.1k and R2=6.8k for 9V full scale). A momentary push switch can apply power and load during testing. The LM3914 circuit can be adapted from existing designs for car battery monitoring to test alkaline cells with multiple LEDs indicating voltage ranges without using a meter.
