AK8963C Compass Module Intermittent SPI Communication with PIC Microcontroller
237 19
Why is my SPI compass module sometimes unreadable by the PIC even though the logic analyzer shows valid data?
The most likely cause is that the compass module’s MISO signal is too low for the PIC to read reliably, and the SPI timing may also be marginal [#21683412][#21683417] The thread found the PIC needed about 2.3 V to switch, while the compass MISO was only about 1.65 V, which explains why the analyzer could decode data but the PIC still failed [#21683417][#21683425] A level shifter or buffer is the recommended fix; a suggested part was SN74LV1T34, which accepts 1.39 V input at 3.3 V supply and outputs about 2.49 V with a 9 ns max propagation delay [#21683423] If you try MOSFET shifting, be aware a basic N-MOSFET arrangement inverts the signal, so a proper buffer is safer [#21683419][#21683421] It was also suggested to slow the SPI bus and verify setup/hold timing on the PIC with an oscilloscope, because excessive delay on the bus can skew the data relative to the clock [#21683412] Another possibility is that something in the PIC is loading the MISO line down, such as an enabled internal pull-down, so that should be checked too [#21683426]
  • #1 21683408
    Terry Ford
  • Check for intermittent connections and SPI signal levels
    #2 21683409
    Elizabeth Simon
  • #3 21683410
    Terry Ford
  • #4 21683411
    Terry Ford
  • Suspected SPI timing skew from cable delays
    #5 21683412
    Elizabeth Simon
  • #6 21683413
    kethrin12 kafe
  • #7 21683414
    Terry Ford
  • #8 21683415
    Elizabeth Simon
  • #9 21683416
    Terry Ford
  • #10 21683417
    Elizabeth Simon
  • #11 21683418
    Terry Ford
  • #12 21683419
    Elizabeth Simon
  • #13 21683420
    Terry Ford
  • P-type MOSFET wiring remains unclear
    #14 21683421
    Elizabeth Simon
  • #15 21683422
    Terry Ford
  • SN74LV1T34 buffer suggested for level shifting
    #16 21683423
    Elizabeth Simon
  • #17 21683424
    Terry Ford
  • Level shifter raises intermittent MISO voltage to 3.3V
    #18 21683425
    Terry Ford
  • PIC pin pulldown may be loading the compass output
    #19 21683426
    Elizabeth Simon
  • #20 21683427
    Terry Ford
A PIC microcontroller system with multiple SPI peripherals, including an AK8963C compass module from an iPhone 5, began exhibiting intermittent SPI communication failures. Initial troubleshooting ruled out solder joints, wiring, software versions, and environmental damage. Oscilloscope and logic analyzer measurements showed inconsistent MISO signal voltage levels, sometimes dropping to 1.65V, below the PIC 18F4620's required 2.3V logic high threshold. Timing issues were considered due to 200mm wiring length, but the main problem was identified as insufficient MISO voltage level causing unreliable logic high detection. Adding a level shifter improved the MISO voltage to near 3.3V and stabilized communication, though not perfectly. Discussion included the suitability of MOSFET-based level shifters, signal inversion concerns, and alternative buffer ICs like the SN74LV1T34 for level shifting. Internal PIC pin pull-ups and drive strength of the compass output were also considered as factors affecting signal integrity.
TL;DR: Intermittent AK8963C SPI reads traced to signal integrity: MISO sagged to 1.65 V while PIC VIH needs 2.3 V; “I suspect a timing issue.” Diagnosis with scope/analyzer and adding a buffer fixed most cases. [Elektroda, Anonymous, post #21683412]
Why it matters: This FAQ helps PIC users quickly debug flaky SPI compass readings using practical, proven steps.
For: PIC18F users integrating AK8963C over SPI who see random read failures or noisy waveforms.
How do I fix intermittent SPI reads from an AK8963C on a PIC18F?
Check MISO voltage first. If highs are ~1.65 V, they miss the PIC’s 2.3 V VIH. Add a unidirectional buffer like SN74LV1T34 at 3.3 V. Then slow SPI and verify CPOL/CPHA to meet setup/hold. Keep wires short and probe near the PIC. This sequence restored stable ID reads (0x48) for the thread author. [Elektroda, Anonymous, post #21683423]
Is this a timing or wiring problem?
Both can apply. Long leads (~200 mm) add delay and edge distortion. The expert noted, “I suspect a timing issue.” Slow the SPI clock, then check clock–data alignment on a two‑channel scope at the PIC pin. If alignment improves at lower speed, reduce cable length or add a buffer. [Elektroda, Anonymous, post #21683412]
What SPI edge should the PIC sample on here?
The setup sampled on the rising edge. Confirm your PIC’s SPI mode matches the AK8963C timing you observe. If data changes near the sampling edge, shift the phase or reduce speed to increase margin. Validate by reading WHO_AM_I = 0x48 consistently. [Elektroda, Anonymous, post #21683416]
Are 200 mm wires too long for reliable SPI?
They can be. The thread used ~200 mm between PIC and compass, which increases skew and ringing. Shorten runs, add series resistors near the driver, and maintain solid ground return. Re‑probe 30 mm from the PIC to verify improvement. [Elektroda, Anonymous, post #21683414]
Why does my MISO logic-high look low on the scope?
Loading or level mismatch. The helper observed MISO “less than 2 V,” which fails PIC VIH. Check for unintended pull‑downs or alternate pin functions on the PIC. Insert a buffer/level shifter to restore high level and edge rate. [Elektroda, Anonymous, post #21683417]
Will a MOSFET work as a level shifter on MISO?
A single N‑MOSFET wired low‑side inverts. Two stages re‑invert but add delay. The discussion favored a 74‑series buffer with a low VIH at 3.3 V. It avoids inversion and has ~9 ns delay, suitable for typical SPI speeds. [Elektroda, Anonymous, post #21683419]
Which single‑gate buffer was recommended?
SN74LV1T34. At 3.3 V supply, it accepts low input thresholds and provides clean 3.3 V CMOS outputs. The data point shared lists ~9 ns max propagation delay, which is acceptable for moderate SPI clocks and cleans up MISO transitions. [Elektroda, Anonymous, post #21683423]
Could the PIC pin be dragging MISO down?
Yes. The helper suspected PIC pin configuration loading the line. Check for enabled pull‑downs or alternate functions. Disable internal pulls on the MISO pin and retest. If the line rises with a buffer inserted, loading was likely. [Elektroda, Anonymous, post #21683426]
What’s the AK8963C device ID I should read over SPI?
WHO_AM_I returned 0x48 during correct operation in this setup. Use it as a quick health check after power‑up and after changing timing or wiring. If it flips or reads 0x00/0xFF, debug signal integrity first. [Elektroda, Anonymous, post #21683414]
Quick 3‑step: How do I isolate the failure fast?
  1. Scope CLK and MISO at the PIC pin; capture good vs bad reads.
  2. Slow SPI and shorten the cable or add a buffer.
  3. Verify WHO_AM_I = 0x48 repeatedly; then restore target SPI speed. [Elektroda, Anonymous, post #21683412]
What is the AK8963C in this context?
It’s a compass/magnetometer module harvested from an iPhone 5, used here as an SPI peripheral to a PIC18F board. The project had several modules and PCBs, confirming the issue wasn’t a single bad unit. [Elektroda, Anonymous, post #21683408]
What’s an edge‑case failure to watch for?
The author saw MISO start near 3.3 V and then drop to ~1.65 V mid‑session. After adding the buffer, the output wavered up to 3.3 V and mostly recovered, but not 100%. That points to residual loading or timing margin. [Elektroda, Anonymous, post #21683425]
Does a pull‑up on MISO help?
A strong pull‑up can distort the waveform by stretching edges. The author tried one and observed the entire short square wave pulled up. Prefer a buffer with defined thresholds rather than brute pull‑ups on high‑speed lines. [Elektroda, Anonymous, post #21683427]
How do I verify the analyzer vs scope disagreement?
Logic analyzers can decode marginal levels due to hysteresis; scopes reveal analog quality. Trust the scope for amplitude and timing. In the thread, the analyzer decoded fine while the scope showed ragged edges. Fix the analog first. [Elektroda, Anonymous, post #21683411]
What’s a good confirmation that fixes worked?
Repeat WHO_AM_I reads until stable at 0x48 across resets and temperature. Then raise SPI speed incrementally while watching setup/hold on the scope at the PIC pin. Document the highest error‑free rate. [Elektroda, Anonymous, post #21683414]
Any expert tip to remember during debug?
“Look for signals with funny levels.” Measure at the PIC input, not just at the sensor. The right probe point often reveals the real culprit. [Elektroda, Anonymous, post #21683409]
